Hi,
This is my first time posting on a discussion forum, but I've tried everything at this point.
I built a PC for the first time and before putting everything in the case I performed an out of the box post test. The components I used were:
- Asus Z170-P ATX LGA1151 Motherboard
- Intel Core i5-7600K
- Vengeance LPX DDR4 3000MHz 8GB
- SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply
- Cooler Master Hyper 212 EVO
When I performed the post test, all the components power up but nothing appears on the monitor screen. I performed the following to try and fix the issue:
- I switched my previous ram to a manufacturer recommended one
- I've re-slotted the RAM
- I re-seated the CMOS battery
- I've RMA'd the motherboard and received a new one
- I double checked the connections between the PSU and the components
- I tested the monitor with my laptop
- I re-seated the CPU and double checked there were no bent pins in the CPU or motherboard
I could not determine if the issue was with the motherboard or the CPU. But now that the motherboard has been RMA'd, it must be the CPU, right?
https://linustechtips.com/topic/758513-problems-posting/
The 7000 series CPUs require a Z270 motherboard (or the lower end ones like B270, etc) or you need to flash your BIOS to one that supports kaby lake cpus.
https://linustechtips.com/topic/758513-problems-posting/#findComment-9587111
I'm still fairly new at this, but I noticed that the Z170-P website does list the i5-7600K as one of its supported CPUs (https://www.asus.com/us/Motherboards/Z170-P/HelpDesk_CPU/)  Though I'm not sure what the validated since BIOS 3017 mean. Is that the flash you mentioned?
https://linustechtips.com/topic/758513-problems-posting/#findComment-9587168
Return your board and get a Z270.
https://linustechtips.com/topic/758513-problems-posting/#findComment-9587185
It means you need to flash the BIOS before that CPU will work because you purchased that motherboard before the 7000 CPUs and that update even existed.
https://linustechtips.com/topic/758513-problems-posting/#findComment-9587191
3 hours ago, Zi_Ren said:
Thanks that explains a lot! How do I go about flashing a new bios to the motherboard if I can't access the BIOS or OS? Any recommendations on material/resources?
Either go to a computer shop and ask them if they can flash the bios or let you borrow a skylake cpu....or purchase a cheap skylake cpu to flash it yourself. Last option is to return the z170 board for a z270 board.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/758513-problems-posting/#findComment-9588034
