Hey guys so i've been streaming abit of league of legends and i can't help but notice my fps not staying at 144 which i am abit of a fps whore :P and it kinda upsets me slightly that i can't keep 144fps in league lol
I've done all the normal stuff 720 30fps 2k bitrate on x264 with no random parameters or anything like that.
My specs are -
i7 4790k
gigabyte z97x gaming 5 mobo
2x gigabyte windforce 970's
HyperX FURY Series 16GB DDR3 1866MHz
Any idea's? I know streaming is very cpu intensive! Do i just live with the fps drops and stop being a fps whore? :( haha
James
https://linustechtips.com/topic/755138-obs-fps/
Here is a tutorial for one way to up that fps.
It is extremely comprehensive, check it out!
As #muricaparrotgang's founder, I invite you to join our ranks today.
"My name is Legion 'Murica Parrot Gang, for we are many."
(We actually welcome all forms of animated parrot gifs.)
The artist formerly known as Aelar_Nailo.
Profile Pic designed by the very lovely @Red :)!
https://linustechtips.com/topic/755138-obs-fps/#findComment-9549480
If you have GeForce Experience installed use Shadowplay (or 'share' as they call it now).
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/755138-obs-fps/#findComment-9549496
Are you using the nvenc encoder?
https://linustechtips.com/topic/755138-obs-fps/#findComment-9549514
Do you get 144 fps when not streaming?
The above mentioned using Quicksync and NVENC which takes the load off the cpu.
The idea being your CPU can focus on LoL.
You can also build a dedicated streaming pc (dual pc setup) though the setup can be complex when it comes to audio.
https://linustechtips.com/topic/755138-obs-fps/#findComment-9551211
Yeah i get 144fps pretty much constantly only really drops when there's a huge team fight and shit is going down so to speak but that's expected.
I was considering making a cheap secondary pc for a stream rig but im currently broke :(
https://linustechtips.com/topic/755138-obs-fps/#findComment-9555259
Where are you doing your downscaling? on the CPU or GPU side??? Since this could be very taxing on the system depending where your are doing it.. also we need a bit more information about your OBS settings... like preset, profile, and such
and btw.. i would go for x264 as that produce the best quality..... NVENC + quicksync does not provide the same good quality as x264...
https://linustechtips.com/topic/755138-obs-fps/#findComment-9555352
where can i see which side it's doing it? preset is veryfast and profile is on main
https://linustechtips.com/topic/755138-obs-fps/#findComment-9580891
