Cant use with my monitor 144hz with 1080 ti ?
zzz123
Hi first. I want buy monitor:  G-Master GB2488HSU-B3 Red Eagle [1ms, 144Hz, FreeSync]
But on Iijama site ,they said this:"
Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144hz refresh rate delivers the crisp and sharp images needed to raise your game. For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI.
But 1080 ti dont have dual link DVI. So how can i plug 1080 ti using 144hz on this monitor? So i cant yes? what a mess
http://gmaster.iiyama.com/it_it/products/g-master-gb2488hsu-b3/
So why they said:"  For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI.
The monitor has DisplayPort connection, 1080Ti does too. Use that.
EDIT: Yea, that might not work then. Some custom cards may come with DVI port, but no promises.
On the other hand, you don't need 1080Ti to get 144Hz at 1080p - you could get away with GTX 1080.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Because a lot of people still uses DVI and 90percent of the DVI cables out there are single link, you on the other hand are going to be using DisplayPort already so it doesn't matter.
Personal Desktop":
Luna, the temporary Desktop:
So why they said:" For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI. "
Display port will work 144hz ?
I wouldn't buy that monitor, it's freesync and you're using a 1080ti, seems a waste. I'm also not sure if it will run 144hz with an nv card, I read somewhere that they needed freesync (AMD) to bump up to 144hz (maybe wrong)
Lastly, please don't go 1080ti with a 1080P screen, if money is the issue go with a 1080 + a good 1440P screen
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Some user with nvidia card said that 144hz support
Honestly, my Predator X34 (3440x1440 100hz) feels like a bottleneck for most games with a 1080 Ti... Don't bother with a 1080 Ti for anything under 2560x1440 144hz.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
4k 144hz from asus is coming later this year. other manufacturers same time frame most likely.
expect your wallet to get balls deep action for it though
DisplayPort will work fine.
Probably they just copy pasted the description from one of their other monitors.
