Core i7 running way too hot...
I bought a 4770k last week and so far I love how well it performs in Blender and Premiere, even compared to the 4690k I previously used. I know these badboys are notorious for running very hot, but I think I scored a particularly bad performing one.
Long story short: I'm using the same cooler as previously with my 4690k and the temps are outrageous. If I start Prime95 at stock speed, the temps immediately jump up to ~90°C on the hottest core. My 4690k never went past 62°C with the same setup while being overclocked to 4,2 Ghz. A bad mount is debarred, I've reinstalled the cooler multiple times now with the same outcome.
Are these temps to be considered normal?
  1. Is it overclocked?
  2. Cooler?
  3. Thermal Paste?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Did you remember to keep voltages the same? It's likely that the 4770k is just drawing more voltage.
Outside of that, the TIM was pretty terrible on Haswell chips, took the, Haswell-R to kimda fix it. Delidding would be a great way to get some lower temps
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
1 minute ago, nerdslayer1 said:
what cooler?
Scythe Big Shuriken 2 Rev. B with beQuiet! Pure Wings 2 PWM fans installed. Like I said, the same setup kept my 4690k at very reasonable temps. I also tested a Corsair H45, kinda got me the same results...
3 minutes ago, PCGuy_5960 said:
Is it overclocked?
no, like I said, it runs on stock speed with stock voltages.
4 minutes ago, PCGuy_5960 said:
Thermal Paste?
Arcitc MX4, same as with the 4690k
i5 vs a i7 is a big difference in potential, get a better cooler, your cooler is a low profile cooler.
Didn't properly read the OP, LOL xD
Arcitc MX-4 shouldn't cause issues. I use it as well and I get amazing CPU temps :D
you *did* replace the thermal paste, right?
Potential is actually the same on P95 small FFT, it's just that HT wastes more energy trying schedule stuff (to no gains, however).
...i was thinking on real life usage especially longterm, OP should get a beefier cooler and push that i7 to 4.5 ghz.
What P95 version? To compare to others, use the "balanced" setting on prime95 26.6. It's the version and settings most people (are supposed to) use to accurately benchmark a systems cooling performance.
Headphones:
Sony MDR V6 (DT 250 pads), restored 1987 AKG K240M 600ohm (Cosmos pads with dt250 filters), AKG K7XX, Beyerdynamic DT990 pro 250 ohm, Bose Ae2 & Sony MDR v150. All off of a Bravo V2 shuguang tube, Little Dot mkII with GE JAN 5654 tubes, a CEntrance Dacport slim and a UCA222.
PC:
  • CPU
    i7 6700k
  • Motherboard
    Asus Z170s
  • RAM
    Crucial Ballistix (white)
  • GPU
    Asus 1070 Strix OC
  • Case
    Phanteks P400
  • Storage
    Samsung 850 pro, Seagate barracuda 1tb
  • PSU
    Evga G1 650W (regret)
  • Display(s)
    Samsung S22D300 21.5" 1920x1080 60hz 5ms & ASUS PB277Q 27" 2560x1440 75Hz 1ms
  • Cooling
    Deepcool Captain 240EX white
  • Keyboard
    Logitech G810
  • Mouse
    Logitech G502
  • Operating System
    Windows 10 (switching to linux soon)
ofc I did...
Wastes....No gains....wat.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
It needs to be, since I have a SG05.
It's exactly that. HT increases pwer consumption a bit while trying to squeeze more performance out of the chip; unfortunately, there's no benefit to it, so the energy ends up being wasted.
Your only hope is to delid it.
Thank Intel for not soldering it to IHS.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Wow. That is so wrong it kinda impressive.
That shows in games the i7's absolutly crushing the i5's in gaming.
That shows a rendering situation where the i7 runs away with the lead with nearly double the performance.
@Hunter259 @Pauleh @nerdslayer1 @Imakuni @PCGuy_5960 @Kommanche thanks for your answers and/or proposed advice guys, but all I asked for was somebody telling me wheter or not those temps are to be considered normal for a 4770k.
Are you sure it's getting airflow? Have you reset the bios? Have you checked to make sure the voltage is actually stock? Are you using AVX instruction version of Prime 95?
You have no idea what you're talking about.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Seems if you bought that CPU used, it may have just poor IHS Thermal past at this point. Probably need a delliding. That is not normal stock/stock full load. Also, have you tried AIDA 64 as a stress test instead? P95 seems to be having some issues if not set up properly. Normal stock/stock with LP cooler should be in the 70's from my past experience
Read my posts and the context in which I've written them and you both will understand what I'm trying to say here.
45 minutes ago, Imakuni said:
Potential is actually the same ON PRIME95 SMALL FFT, it's just that HT wastes more energy trying schedule stuff (to no gains, however).
If you're not paying attention to your CPU and are just letting it do it's thing, yes, those temps, while too high for comfort, are normal. If you are taking care of your CPU, however, then there's a problem, hence why each one of us is asking / suggesting difrerent things.
