Core i7 running way too hot...
2 minutes ago, Imakuni said:
Read my posts and the context in which I've written them and you both will understand what I'm trying to say here.
Uh. It does improve the speed at which you can find Mersenne Prime numbers.... I'm failing to see how it's "wasting" energy.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
2 hours ago, Vulcanis said:
Seems if you bought that CPU used, it may have just poor IHS Thermal past at this point. Probably need a delliding.
I actually did buy it used. Bad tim might very well be the reason for all I know. I really don't want to delid it though. I never delidded a cpu before and I guess I'm screwed if something goes wrong...
2 hours ago, Imakuni said:
If you're not paying attention to your CPU and are just letting it do it's thing, yes, those temps, while too high for comfort, are normal. If you are taking care of your CPU, however, then there's a problem, hence why each one of us is asking / suggesting difrerent things
I do care, thats why I asked.
Well, I really don't want to delid the 4770k, but it seems I have no other choice.
23 hours ago, black0utm1rage said:
@Hunter259 @Pauleh @nerdslayer1 @Imakuni @PCGuy_5960 @Kommanche thanks for your answers and/or proposed advice guys, but all I asked for was somebody telling me wheter or not those temps are to be considered normal for a 4770k.
It's also hard to define normal temps. 4770Ks are notorious for poor IHS contact so the temperature range from an OK chip and a poor chip can be 20C!
Only way to solve this is to delid. Your temps are high so it seems like you might have a chip with poor IHS contact.
