Best Asus Aura compatible led strip
be_x
I am looking for an rgb and uv hybrid strip thats companionable with asus aura
Is cablemod Widebeam the only one?
Are there any others that are better or no?
Cable Mod currently is the only one that has an RGB and UV LED integrated into on unit however it will not work with Asus's Aura system since it is only 4 pin RGB. The RGB UV or White strips require 5 pins which I believe only Gigabyte has currently integrated.
Is an RGB UV different from an RGB and UV Hybrid?
Cable Mod just calls it their hybrid LED strip since it integrates both RGB and UV into one strip.
Hey @be_x - as @W-L mentioned the hybrids are not compatible with the ASUS Aura software because the hybrids are a 5-pin design and the ASUS Aura header on the motherboard is a 4-pin design. We do have kits you can purchase to control the Hybrids of course though if you're interested in going that route.
