Need help me in buying new power supply
Doge99
21 minutes ago, xD Power Hole Stick said:
ok what about eps you are telling having problem
First of all you should not try to power up a 95w CPU with single 4 pin CPU connector when the motherboard requires two 4 pin CPU connectors (which is called the one 8 pin EPS connector) as overheating may occur and cause fire.
Second you should not power up the 95w CPU with a no name PSU as bad PSU can't deliver enough power to power hungry CPU and it may cause damage to your whole system.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Desktop specs:
c
Yes.
can it power my whole build
5 minutes ago, ZM Fong said:
Yes.
i find some cheap psu from other mainstream reatailer
6 minutes ago, ZM Fong said:
Yes.
i will updrage my psu in late April or early may
1 hour ago, xD Power Hole Stick said:
@STRMfrmXMN
According to my info it's based on the cooler master b series so not good.
Desktop specs:
Just now, ZM Fong said:
It's based on the cooler master b series so not good.
so what
Just now, xD Power Hole Stick said:
so what
Get a better PSU.
Desktop specs:
Get a better PSU.
but what and reasonable price
The Seasonic S12 you linked before is a good choice.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
3 hours ago, ZM Fong said:
If you really can't afford PSU from tier 1 to tier 3, look for tier 4. If not you better save up for a good PSU.
2 hours ago, ZM Fong said:
Try searching every PSU from the tier list in your country.
Desktop specs:
http://www.amazon.in/Seasonic-S12II-520-Watt-Power-Supply/dp/B005O8PNSM/ref=sr_1_1?ie=UTF8&qid=1489408692&sr=8-1&keywords=Seasonic+S12II+520 this one
and i am so sorry for troubling you for asking too many question  and finding my answer
That is the right PSU, yes. Buy that one.
