Need help me in buying new power supply
Doge99
i want to overclock my 750 ti but my psu is some local 310 watts psu
i have see that there was 4 pin eps connecter was missing
i see in hwinfo64 on tdp was only 30 watts
in my place i can buy corsiar vs 550 psu it is good
pc spec
gigabyte 78lmt-usb3 rev-5.0
amd fx 4300
gtx 750 ti
8 gb ddr3 ram at 1333 mhz
detailed spec in photos
pls help me
thanks
Get any PSU from tier 1 to tier 3.
Don't get Corsair VS.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://www.amazon.com/gp/product/B00390P1NO/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
Good PSU for relatively inexpensive (Tier 3 on the list)
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
it cost me more
Just now, xD Power Hole Stick said:
it cost me more
What's your budget?
Desktop specs:
1 minute ago, ZM Fong said:
What's your budget?
in my country is expensive
40$to$50
40$to$50
If you really can't afford PSU from tier 1 to tier 3, look for tier 4. If not you better save up for a good PSU.
Desktop specs:
what about eps missing in my psu
is coriaer vs 550 is good $57
Most of the PSUs nowadays have EPS cable.
Avoid Corsair VS450/550/650 PSUs. They belong to tier 6 which is bad.
Desktop specs:
my motherboard required 2 4 pin eps and my psu has only 1 4pin eps connecter
and can you recomand any cheap good psu that cani buy in my country at reasonable price
Where do you live?
Desktop specs:
india
Try searching every PSU from the tier list in your country.
Desktop specs:
in this country
only vs power supply are reasonalbe
and other nice psu go above my budget
that is a problem and help to increase tdp?
28 minutes ago, xD Power Hole Stick said:
in this country
Then save up for a better PSU. You can't cheap out on that.
Help to increase tdp? What do you mean?
Desktop specs:
this processer has a tdp of 95 watts but with is psu it only go to 30 watts on load
it is ok
Definitely having problems.
Desktop specs:
what are they
is cm b500 is ok
hello?
55 minutes ago, xD Power Hole Stick said:
is cm b500 is ok
With your budget at least go for tier 4 PSU.
Desktop specs:
ok what about eps you are telling having problem
