so i just bought an i7 4790 to upgrade my i3 4170 from what fps gain should i expect in games form it and what gfx card would b a worthy upgrade from a gtx 770?
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/751006-i7-4790-fps-boost/
RX 480
you should see pretty huge gains for , well everything. You are going from a dual core i3 to a quad core i7. Most modern games can utilize up to 4 cores and suffer if it doesn't have 4 physical cores. Multi tasking would also benefit
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505128
1 minute ago, nerdslayer1 said:
you will gain a good amount of frames, get a 1070 if you  have the money or a rx480.
could my i7 do sli 1070s?
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505140
It depends on what games you're playing. Multi threaded games like battlefield 1 will see huge performance gains while single threaded games won't see much improvement.  A GTX 1070/1080 would be a good upgrade for that CPU, however you might find the performance boost you get from the CPU upgrade to be enough for a little while yet.
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505147
cheers all for the help and quick replies
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505159
Don't use SLI.  It's a nice option if you've got one card and someone gives you another one super cheap, but plenty of times you'll find yourself having to run games on a single card to eliminate all issues.  A single nicer card is always better than two weaker cards.
6 minutes ago, Droidbot said:
Yes, but doesn't mean it's worth it. Sell your 1070 and upgrade to 1080/Ti instead :))
He has a 770, not a 1070.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505200
I was meaning if he had a 1070 and wanted more power, not that he does atm lmao
idk
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505203
have you used sli because i have heard from people with sli rigs say they have had very positive results form using it
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505204
it depends on the motherboard
depends on which game. can't tell how much fps will you get as each game utilizes cpu differently
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505206
i understand that the motherboard requires sli compatibility
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505215
Personally, I have used SLI with GTX 980's. The gain was not worth it but the cool factor was. I'll put it to you this way. Don't cheap out by buying 2 cards. As an example. Why would you spend $900 on two 1070's when a 1080Ti probably kicks it into the ground? 1 power card is always better than 2 cards. Why? Micro-stuttering is a bitch and not every game utilizes SLI completely. Even if they do, you can still get issues.
ANY i7 will support SLI just fine. It's up to you if you want to spend the money towards a good $200+ motherboard in order to achieve that PLUS the cost of 2 cards which, at that point, you could of saved money towards one powerful card, the 1080Ti, and be done with it for the next 3 years or so.
Catch my drift?
*Insert Name* R̶y̶z̶e̶n̶ Intel Build!  https://linustechtips.com/main/topic/748542-insert-name-r̶y̶z̶e̶n̶-intel-build/
Case: NZXT S340 Elite Matte White Motherboard: Gigabyte AORUS Z270X Gaming 5 CPU: Intel Core i7 7700K GPU: ASUS STRIX OC GTX 1080 RAM: Corsair Ballistix Sport LT 2400mhz Cooler: Enermax ETS-T40F-BK PSU: Corsair CX750M SSD: PNY CS1311 120GB HDD: Seagate Momentum 2.5" 7200RPM 500GB
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505273
Google i7 4790 reviews and look at gaming benchmarks in those reviews.
Surely some of the results would be put against the i5 and i3's.
Here is a decent comparison IMO
http://www.anandtech.com/bench/product/1199?vs=1197
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505319
Catch my drift?
im not buying two 1070s straight up im buying one but was wondering if the i7 could do sli if i wanted it down the line otherwise i would buy a 1080ti straight up over 2 1070s
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505332
But didn't you already know the answer to the question about the i7 being able to SLI since you knew it came down to the motherboard? Hell if the motherboard supports it, a Pentium could do SLI. I would never buy a 1070 and SLI later. If that's what you're planning, go with a single 1080 or single 1070 and just wait to do SLI once Nvidia releases the new generation.
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505353
i meant without bottleneck and a 1080 costs alot in my country so the 1070 is a much nicer alternative
CPU-I7 4790
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505368
Which I understand. But, if you're planning to SLI, why not save money in the long run by saving up for one 1080? Not to mention, your thermals and your electric bill will be lower too haha.
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505385
The few situations I would probably go with a gpu setup would be as follows.
1) The single strongest GPU cannot accomplish what I want.
2) I'm already running a multi setup for some compute application that uses them, so why not SLI/Crossfire for gaming.
3) The card(s) can be had for an extraordinarily good deal.
4) My wallet is just too heavy, and I want the cool factor of RGB Quad GPUs (even though I can never use them all at once).
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/751006-i7-4790-fps-boost/#findComment-9505470
