GPU power consumption question
Solved by be_x,
Just now, Vanguardas said:Let's say I'm AFK in a game. I turn off my monitor, but I leave my game running. The GPU should consume power close to its idle power consumption right?
Regardless if your screen is turned on or not, your gpu (usually a big power hog) and your cpu (also big power hog) are still rendering the game. So no it wouldnt really be any less than if the screen was on
