My Ryzen 1700X build!!!
JoePro87
Well, here it is. I spent WAY too much money on it, and still had to settle (was wanting the 1800X, but I doubt it would make much of a difference.  Also, I know, my cable management isn't that good. Unless someone wants to come to Indiana and help me fix it, I don't want to hear it, lol. Oh, I'm technically not REALLY done, because I had an air cooler, and I'm about to install a CoolerMaster MasterLiquid Pro 240, but aside from that...I finally got it done! What do you all think?
Specs:
CPU: AMD Ryzen R7 1700X
GPU: Asus Strix GTX 1080
Mobo: ASRock AB350 Pro 4
RAM: 32GB G.Skill Ripjaws DDR4
SSD: 500GB Samsung 850 Evo Pro
HDDs: 2X 4TB Seagate HDD's in RAID 0
PSU: Corsair RM850x
Case: Enermax Ostrog ADV Blue
Screenaninator: Sapphire Radeon R9 390 Nitro
Procrastinator: AMD FX-8300
Stickaminator: 16GB Crucial Vengance DDR3
Powermathingy: Corsair RM850i
attachamajiggy: Asus M5A97 R2.0 f
Remembrerthing: 240 GB Crucial SSD, 2TB Toshiba HDD
I got my 1700x today and from everything I saw the gap from 1700x to 1800x is like 4-5 fps, not worth it. However the jump from 1700-1700x is like 10-15% which makes more sense for the money.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
That CPU 8-pin really messes with my ocd, I suppose your case doesn't have a cutout on the top?
If its long enough try routing it around the motherboard or try the old threading it under the GPU and around the rear I/O cutout trick, should be able to fasten it with a couple of zip ties.
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
"The tragedy of the poor is the poverty of their aspirations" Adam Smith
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
For the love of Talos please do some decent cable management. =)
No, it is KILLING me that it doesn't. And, it isn't long enough to do anything else with...that I can think of. But, I SHALL FIGURE SOMETHING OUT!!!
Right, and we can OC to get that extra performance anyway :P
You get -1  point as OP already said he is aware of cable management - But you get plus 10,000 points for praising Talos. Praise the 9 divines :D
So I have been given over 9 thousand points from you.
If you dont thread it around the back of the mobo tray you should be able to pass it around the motherboard, behind the GPU. If not, get some cable extensions, it's only like $20 for a 24 pin, 8 pin and PCI-e extension.
You could also cut a routing hole yourslef.
EDIT: also try passing the GPU power cable from behind the motherboard tray through the gap where the hdd case is instead of the cutout.
Oh trust me, I will. I just have to wait until my wallet stops crying in the corner.
Just now, Abyssal Radon said:
That build looks like a winner. Nice one, enjoy the system.
Thank you! ^_^ It's a hell of an upgrade from my 8350/R9 390!
Cooler?
✨PC Specs✨
AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME
BeQuiet Dark Rock Pro 4 Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A
Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402
1 minute ago, ShadowTechXTS said:
Cooler?
CoolerMaster MasterLiquid Pro 240. It wasn't in the pic, but yeah.
