I opened up my card in the past, which is why part of a thermal pad is missing. I opened it up because I felt it was too loud and was checking to see if there was anything wrong. One of the pads does not completely cover what I think is the VRAM. Is this okay? Also can the pads be ripped?
https://linustechtips.com/topic/746069-cpu-thermal-pads-ripped/
Just replace the pads it only costs a few bucks just make sure to get ones of the same thickness.
https://linustechtips.com/topic/746069-cpu-thermal-pads-ripped/#findComment-9450364
You should replace the thermal pads.
https://linustechtips.com/topic/746069-cpu-thermal-pads-ripped/#findComment-9450474
If there was a thermal pad on it originally, it means that the component gets hot, and there should be a functioning thermal pad on it always.
just get replacements like everyone else said.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/746069-cpu-thermal-pads-ripped/#findComment-9450481
You could replace them. They can be ripped as it's more about surface area and transfer.
Not all cards have active cooling for the all of the vram. So it will be fine either way if you aren't afraid to use the fan on the card.
https://linustechtips.com/topic/746069-cpu-thermal-pads-ripped/#findComment-9451418
