Running two operating systems at once
Solved by BuckGup,
No SteamOS might actually make it perform worse depending on the dev. As for dual booting just partition a piece of the hard drive for it. Install it in that and if it asks install Grub so you can choose windows or linux at start without going into the BIOS
Macaw ·
Posted in Console Gaming0 -
1
Shahrad ·
Posted in LTT Releases1 -
4
frozensun ·
Posted in Graphics Cards7 -
kisserik93 ·
Posted in Peripherals11 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory14 -
3
