Queitest cooler for i7-7700k
drhousedk
Hi,
This has probably been asked a plethora of times before (for gaming rigs - which this isn't) - what is the quietest air cooler for an i7-7700k processor? The case is a Fractal Design Define S. The pump in the block of the Coolermaster Seidon 120V v2 kit is apparently annoying to my friend for whom I built the rig, so... Even less noise is wanted.
The CPU load is in the low end, and the computer won't be used for gaming at all.
Troels
If pump noise is a problem The quietest cooler would be a heat sink with the fans turned down.
How about a giant aluminium heat sink from Noctua?
Just remover the fans and boom, silent.
realistically, its about the fans on the air cooler and the fan curve applied. if youre not doing anything super intense, there's no reason to get anything more intense than a hyper 212x or 212 evo with a or 2 be quiet pwm fans or noctua fans. and turn the fan curve way down.
Some low-profile cooler from Noctua like the NH-L9i would be good.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
Water cooling is usually not that quiet unless you go crazy with huge rads and dozens of fans that all run ridiculously low.
Since your friend doesn't game, and usage is expected to be on the low end, have you ever thought about completely passive cooling? You could grab some of BeQuiet's huge heatsinks and run it without a fan :P Either way, for silence, I would recommend either BeQuiet or Noctua.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
Go with a larger Noctua cooler. They come with quality fans and are near dead silent. But really, any cooler rated for your TDP is fine. Then just add quite airflow fans to it. They are, after all, the only thing making noise. Voila. Silent solution. I've never dived into the loudness of fans but I'm sure someone here has, or Google is an excellent research resource.
If you're trying to make your computer silent, did you get a graphics card that doesn't spool up to a certain temperature and a silent case?
I don't think they're rated for his TDP.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
4 minutes ago, dizmo said:
Go with a larger Noctua cooler. They come with quality fans and are near dead silent. But really, any cooler rated for your TDP is fine. Then just add quite airflow fans to it. Voila. Silent solution. I've never dived into the loudness of fans but I'm sure someone here has, or Google is an excellent research resource.
So it isnt, should have checked, a NH-U14s will do fine though.
PSU Tier List
My specs
PC:
Peripherals
I'm running a Noctua NH-D14 in my own rig (i7-6700k). On "factory" setting (without the resistor in line) I found it quite noisy compared to the old box cooler I used to begin with (came from my i7-2600k). Even with the resistor in line, I find it to be only on par with the box cooler. Kind of baffles me.
im using nh-d15 i can't hear it on  nzxt h440 and temperatures are awsome
There's no factory setting for the cooler. Any control should be coming from where you plug the fans into.
Is your friend oc'ing? Where are you shopping/located? Budget?
