Just now, _NightHawk^^ said:
I'm currently looking for a new gaming pc and i have problems with choosing the CPU i have looked at the i3 6100 but i don't know if its good enough for gaming
Please help me. Thanks
Wait for Zen, if not to buy one at least to know whether Intel will drop prices to match AMD's prices. Also it is pretty important to know which GPU you are using since that gives insight into which CPU would not bottleneck that GPU.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9394238
20 minutes ago, _NightHawk^^ said:
But with i5 then?
Thanks for replying ^^
Btw the games im playing is Assasin's Creed, Battlefield 4, Minecraft, Evolve Stage 2 and CS:GO
honestly, the budget option is the g4560 - or you can wait for the 4 core 4 thread zen processor to come out
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9394306
35 minutes ago, _NightHawk^^ said:
But with i5 then?
whats your budget and your computer specs? and i would wait for ryzen too before getting a cpu now
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9394357
AC Unity/syndicate will be too taxing at the 6100, wait for Ryzen regardless, but a h110m with a 6500 would be neat enough for gaming.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9394492
Don't get that, the kaby lake pentium g4560 performs very similar to that processor and costs much less than the i3 6100...but of course make sure you get a mobo that supports that cpu (there are some that are under 60 dollars)
Entry level gaming cpu, g4560 if you can find a good motherboard under 60 dollars....If not then, i guess that i3 6100 is a good step forward
I5 for good performing cpu
Don't call me a nerd, it makes me look slightly smarter than you
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9395183
Don't buy anything until ryzen launches
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/741051-what-cpu-do-i-need-o/#findComment-9395432
