Short version? For a user who will only be using their PC for web-browsing, email, and other assorted low-energy tasks, will the stock Intel CPU cooler be enough?
Long version? My mother is a retired teacher, but still does a bunch of babysitting and care-giving work in her neighborhood. For the last several years, she's been orchestrating all of this via email on her phone, and as you may imagine, that brings a fair number of headaches with it. Attachments frequently won't load, she can't directly print out important documents she gets sent, so on and so forth. So to help alleviate those headaches, I offered to build her a new computer since I've recently finished building my own, and did so problem free. We ordered all the parts last night, including a Corsair AIO CPU cooler, but I found out this morning that apparently, the i3 7100 CPU we ordered actually comes with its own stock cooler. This caught me off guard, because I was under the impression that Intel no longer included coolers with their CPUs. Especially since the i7 6700k I bought for my rig a few months ago didn't come with one.
Granted, now that I've said that "out loud", I realize that it makes no sense on Intel's part to include a stock cooler on an enthusiast-grade chip, since the user would almost certainly replace it anyway for the sake of overclocking.
In any case, my question remains the same. For a user who won't be doing anything other than web-browsing, email, word processing, and document printing, would a stock Intel cooler be sufficient to keep the CPU safely cool?
https://linustechtips.com/topic/739019-intel-stock-cooler-quality/
Short answer: yh
long answer: yeah
bregsit
PC specs: i7 4770s, Zotac GTX 1070 Mini, 16GB DDR3L 1600MHz (2x8GB, cheap Crucial RAM), Crucial BX500 480GB , 2x WD Blue 1TB, Seagate Barracuda 1TB, Windows 7
Laptop Specs: i5 5350U, Intel HD something, 8GB (probably DDR3 idk), 128GB Samsung(?) SSD, MacOS whatever the newest one is
Sure it will. Especially for i3 CPUs. You are good to go with it
it is fine, even if you'd game. If you live in a pretty hot environment, it would run pretty hot, but in every half decent room with temps between 20-30°C it is fine
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Lol mine is fine (if a bit loud) at like 35C on a quad core. You don't need a cooler
That's an F in the profile pic
i meant 20-30°C room temps.
Have had a system with an i5 4460, didn't exceed 65°C maxed out
- Ryzen Build -
2x Dell UP2516D
TL; DR: yes, keep it, for lightweight tasks you wont need it, but its preferable to replace the termal paste.
Its fine, It will keep your cpu between working temps always, but Its always better to run you cpu at 40º - 60º rather than 60º - 80º. It gives you longer lifetime to your cpu and It also prevents thermal throttling at 100% usage. What I would never keep is the stock termal paste. It almost glues your cpu to the heatsink if you dont replace it, I dont know how many years It takes to became "glue" but Ive removed many stock coolers with the cpu of the mobo because I just couldnt separete them.
Thanks for that. I was actually just looking through my drawers to see if I still had the thermal paste I used for my own build, and I do, so I'll be sure to use that instead. :)
Your welcome! Always willing to help :D
