Done.
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
Done and I don't eat breakfast.  I only eat once a day.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
Done!
I lied on every question to give the survey a margin of error   :D
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
