Controller for PC
Go to solution Solved by SV4NL,
That's settled then, I'll be getting the Xbox 360 controller. Thanks to you all ^^
-SV4NL
I know I know, keyboard and mouse all the way...
but, some games i cant play without a controller. My PS3 controller broke this week and I need a new controller for games like Rocket League. My budget is kind of tight at the moment so I picked out a few sharp-priced controller with their respective pricing in my country:
Microsoft Xbox 360 Controller  € 35,94    By most people regarded as the best PC controller. Seems like the best bang for the buck and best controller of these in general, the only thing that has me kind of skeptical is that I have always played on playstation controllers and that i might not like the layout. If anyone faced the same situation please tell me.
Logitech F310                          € 29,99    This controller has a lot of positive reviews and has the same layout as a PS3 controller
Gioteck VX-2                            € 21,98    Cheapest controller, cant find a lot of reviews on it. If there is anyone who has this controller please tell me what you think of it.
So if anyone has faced the same situation with the playstation to xbox controller switch please tell me because that has the most influence on this decision.
-SV4NL
CPU: Intel Xeon E5320 @1,86GHz | MOBO: A random HP MOBO… | RAM: 8GB (2x4GB) DDR2 | GPU: NVIDIA Quadro FX 1800 | CASE: HP xw6400 workstation case | PSU: Random HP PSU| [spoiler=
HellFire (1st build)] CPU: Intel i5 4690k | MOBO: MSI Z97-G45 GAMING | RAM: GSkill Ripjaws X 2X4GB | GPU: MSI GeForce GTX770 GAMING (2GB) | CASE: Zalman Z11 PLUS HF1 | PSU: Corsair CS550M | FANCONTROLLER: NZXT Sentry 2 | Storage 300 gb WD VelociRaptor/ 1TB WD caviar green|
mouse/keyboard: CMStorm Devastator | Headset: Plantronics RIG|
If you need me, just quote me!
https://linustechtips.com/topic/732654-controller-for-pc/
-SV4NL
get the 360 controller. it has the best windows support.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9307589
Xbox 360 controller is best for compatibility, especially if you get a wired one (I'm not sure if the wireless is as compatible). Otherwise I'd get the Xbox One controller.
If you don't mind setting it up, I would take the PS4 controller though. I find its layout makes more sense than the Xbox's and it has a decent D-pad (the XB1 is better than the XB360's, but it's clicky, so it makes it hard to roll inputs)
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9307619
I used both Playstation and Xbox controlers and in my opinion I would go with Xbox 360 controller. I played on PS from when the first came out and changed to xbox360 instead of getting PS3 and.. in my hands it just feels better.  Can't say anything about newer gen controllers though.
And about compatibility of wireless 360 controller. Didn't have any problems and if I want to make custom setup for example MMO it can be done as easily on Xbox and Playstation controller using xpadder.
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9307732
Try to look for a used Xbox One controller, I definitely prefer their feeling in my hands opposite to xbox 360 controller (although, I loved that controler, too).
And yeah, it would be best idea to get a controller from microsoft since it would mean it's optimized well.
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9307814
360 (I like the stiffer analog sticks) and xb1 controllers (lighter, better everything except the sticks).
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9307858
-SV4NL
https://linustechtips.com/topic/732654-controller-for-pc/#findComment-9308367
