best 50$ cpu cooler (am3)
XIGMATEK Dark Knight II SD1283 Night Hawk Edition or Hyper 212 Evo with a NF-F12 on it.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1002452
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1002455
No need for an aftermarket fan.
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1002468
there is always a need xD.
stock is just such an ugly word these days :D
Well the stock 212 Evo fan is pretty decent as is.
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1002867
I can vouch that the  Xigmatech Dark Night II Night Hawk works quite well. I got one and have been very happy with it.
Main rig: Coursair Air 540, Amd 8120(stock clock, had it up to 4.6), Gigabyte 990 fx ud3,  MSI DCU2 r9 280x, seasonic 1000w platinum, Samsung 830 64 GB ssd, Seagate 1tb, 4 GB (2x2) G.Skill,
Secondary: Define r4, Amd A10 5800k(4.6), 1x Sapphire 7950, MSI FM2-A85xa, 8 GB coursair vengeance ram, Seasonic 1250w Gold, 500GB 840 Evo, 223GB 2.5 Hdd, 80 Gb Seasonic, Samsung CD/dvd
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1006258
i want to go with a
Cooler Master
V6 GT is it good ?
The Cooler Master V6 GT / V8 / V8GTS / V10 looks....cool (or stupid and bulky), but it doesn't perform that great.
- Cooler Master Hyper 212 EVO
- XIGAMTEK Dark Knight II
- Phanteks PH-TC12DX
- The original Thermaltake Frio (get aftermarket fans if you want...because they are loud at high RPMs)
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1009223
CPU: Intel Core i5 2500K 4,6GHZ OC MB: MSI Mpower z77  RAM: Kingston Genesis 1600Mhz CL9 16GB
GPU: ASUS R9 290 Direct CUII  PSU: Corsair AX 860
https://linustechtips.com/topic/73151-best-50-cpu-cooler-am3/#findComment-1009701
