So I've got 120GB SSD and it's currently at 1.5GB. I've used CC cleaner and only removed 200MB and also tried disk cleanup. Did nothing.Why is my the space running out?
https://linustechtips.com/topic/728517-ssd-storage-running-low/
Because it's full of files...?
Use windirstat to see what is taking up the space.
Also, you should always have 10% or more free space on an SSD, you might have screwed something up by only leaving 1.5GB.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262480
Do you have 118.5 GB of stuff on you SSD? You might have simply run out of storage.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262481
Hi,
A) you may have a lot of stuff in recycle bin, did you try to clear that?
B) might just be you have too many applications/files on your drive. Do you store pictures, videos etc. on that RAID0 array or on the SSD?
speaking of RAID0, I hope for your good you back up your array frequently (e.g. weekly)...?
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262488
Haven't even installed any applications. It was at 10GB 2 days ago.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262491
Run disk cleanup type it into your search bar, click cleanup system files button, this will remove any Windows.old folders you may have, which can take up a LOT of space if you have gone through multiple resets, or insider builds.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262495
Wiered! Check for viruses. Use malewarebytes.
42
also,
My build:
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262498
I've already said I used disk clean up. Also, there is no Windows.Old folder
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262502
Check your SSD have you got a folder named
$Windows.~BT
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262506
Maybe the swapfile grew? If you have other drives in the system, limit the size on the boot drive and allow it to grow onto other disks.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262527
Do I turn it off on the SSD?
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262536
You don't want to do that. You always want a pagefile on your C: drive or you're risking corrupting Windows or causing issues down the line, just let Windows manage it. I have two computers that have a 120GB SSD as my C drive and I even install most of my programs (except for games) on it. Both have over 40GB of free space.
My first guess is that you have things installed to it you didn't realize were installed to it. Check your programs and apps list. Also if you download a lot make sure your downloads folder isn't full of stuff. Finally, many programs will install their cache or temp folders to the C: drive even if they are not installed on the C. Music programs like Spotify or iTunes need to be told where to put their caches and media folders which can take up a lot of space. Same with editing programs like Premiere.
Start narrowing down which folders are using up the space (don't forget to look at hidden folders as well). "Windows" should only be using 20GB or so. If "Users" is taking a ton of space then it's either your files (photos, videos, downloads, etc) or it's app data and you need to narrow down which programs are using it. If "Program Files" is using a ton then it's programs you have installed on C and you should uninstall the big ones and have them installed on your second drive instead. Just start figuring out where the bulk of the data is and what the source of the files are, then report back and we'll see what the issue is.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262683
Well, there is a hidden folder in C:/ called ProgramData. Using around 11GB.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262725
After seeing the screenshot, this isn't it. In total it is only using 1.5GB out of a recommended 3GB. For systems especially with a lot of ram, Window can grow it quite a lot, but that doesn't seem to be happening here.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9262726
That's not that bad, mine's around there too.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9263106
Download WinDirStat, run it in administrator mode, and either attach a screenshot or inspect it yourself. Also note that the System Volume Information folder on the root of C:\ contains system restore data, and can grow quite large. You can certainly disable System Restore to free up some space, but keep in mind this will remove your ability to revert back days or weeks before you installed certain programs.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9263414
It was from AppaData. 45GB just from Adobe Premiere Pro. :o
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9263832
Do explain in further detail, it will be news to many of us.  How exactly does relocating your page file to another drive 'risk corrupting windows'?  Do you understand what the page file is for?
I (and many others) have done this countless times in the past for systems with smaller C: partitions.  With 16GB of ram, he has very little to worry about with the OS actually entering in to a live swap state and if it does, there's no hard with it being on a secondary disk.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9266149
From what I have read: this is because the pagefile is used in the event of a crash as the memory dump which may cause issues if you move the location entirely off the C. This also (apparently) sets up a security risk since monitoring programs often pay less (or no) attention to secondary disks and if your virtual memory is targeted it can give malware easier access to the OS.
As you said, I had done this in the past when I had a system with a 32GB OS drive and ran into some issues after a few crashes (although I can't say for sure that was the exact cause, I haven't had issues since). What I do now instead is let Windows manage the pagefile on C but also allow an overflow pagefile on a second drive to do the bulk of the work.
So, it's possible that I'm wrong and there are no issues but it's just a little thing I had read about a while back and stuck with it. Not to mention having the virtual memory on the fastest drive seems advantageous and the pagefile is relatively small so it's certainly not what is causing his space issues anyway.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9266465
It's an overflow for system-committed memory or a crash dump, in the event that you do not have enough ram available.  Paging and Dump files were more important with 32-bit versions of Windows due to addressable memory limitations.  A page or dump file is purely optional and the only time there would be a concern is if you're overallocated with memory (no page file means no additional 'memory pages' to hand out); working off a pagefile is anything but enjoyable.
So, if you were running in to 'issues and crashes', assuming you didn't allocate a drive for paging file storage then you likely ran out of memory.
It would be in the OPs best interest to move the paging file off of C: to free up space, a practice that Microsoft shared before.
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9267121
Yes, you should place your Adobe media cache and preview files on a secondary drive (can be found in your Premiere settings). You should only have the Adobe install files on your OS drive but all caches on another drive (ideally you would have a dedicated SSD for the cache/preview files and a third drive for your media, but not everyone can). You should also make it a habit to clear your Adobe cache whenever you are done with a project.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/728517-ssd-storage-running-low/#findComment-9267145
