Hey guys. I was hoping to get some input about a new rig I want to get. I'm a pretty big gamer, and I like to have two monitors and multitask between games, videos, and web browsing. My old rig is a few years old now and the it's not able to keep up with the newer games. The budget is $1000. Here's what I have picked out so far:
CPU: Intel Core i5-7600
Mobo: MSI B250 PC MATE ATX
RAM: G.Skill Ripjaws V Series 16GB (2x8GB) DDR4-2400
Storage: Samsung 750 Evo 500 GB 2.5" SSD
GPU: Gigabyte GeForce GTX 1060 3GB Windforce
PSU: EVGA SuperNOVA G2 550W
Case: DIYPC Zondda-B ATX Mid Tower
Total Cost: ~850
Thoughts? Does everything fit together? Suggestions for more preferable/optimal parts?
Thanks!!
https://linustechtips.com/topic/726650-help-with-my-new-pc/
PCPartPicker part list: https://pcpartpicker.com/list/6kwYbj
Price breakdown by merchant: https://pcpartpicker.com/list/6kwYbj/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
CPU Cooler: be quiet! Shadow Rock 2 51.4 CFM Rifle Bearing CPU Cooler  ($46.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z270P-D3 ATX LGA1151 Motherboard  ($110.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($66.89 @ OutletPC)
Storage: Crucial MX300 525GB M.2-2280 Solid State Drive  ($134.99 @ B&H)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.89 @ OutletPC)
Video Card: XFX Radeon RX 480 8GB GTR Video Card  ($259.99 @ Newegg)
Case: Thermaltake Versa N21 ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($50.89 @ Newegg)
Total: $1025.60
Generated by PCPartPicker 2017-01-21 19:45 EST-0500
here you go :D
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241323
I'd say unless you use network storage or external storage, and really want to focus on the RW speeds, you could get a lot more value for your buck if you went for a smaller capacity SSD and bought a 1TB (or bigger if you want) HDD. HDDs are inexpensive. Only drawback in my mind is the writer head making those clicking noises.
CPU: Intel Core i5-6600K @ 3,5GHz
-Cooler: Cooler Master Hyper TX3i
Motherboard: MSI B150 PC Mate LGA1151 ATX
Memory: Kingston HyperX Fury 16GB DDR4-2133MHz
Case: Corsair Carbide Air 540 White
-Fans: 3x Corsair HD120 1x Corsair AF140L
GPU: EVGA GeForce GTX 1070 FTW
PSU: Corsair CX600M
Storage: Crucial BX200 240GB SSD (System disk) + Seagate Barracuda 1TB HDD (Storage)
Operating System: Windows 8.1
Partpicker: https://pcpartpicker.com/list/wPhTtJ
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241329
If you need just the pc, try this:
CPU: Intel Xeon E3-1230 V5 3.4GHz Quad-Core Processor  ($251.99 @ SuperBiiz)
Motherboard: Gigabyte GA-X150M-PLUS WS Micro ATX LGA1151 Motherboard  ($78.98 @ Newegg)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory  ($81.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($67.99 @ SuperBiiz)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($376.99 @ SuperBiiz)
Case: Rosewill GRAM ATX Mid Tower Case  ($39.99 @ Newegg)
Total: $995.71
Generated by PCPartPicker 2017-01-21 19:46 EST-0500
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241331
Since @herman mcpootis and @Bananasplit_00 has already covered where you're maxing out your budget, here's a $750 build :)
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($198.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard  ($73.98 @ Newegg)
Memory: Team Dark 16GB (2 x 8GB) DDR4-2400 Memory  ($84.99 @ Newegg)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($133.99 @ SuperBiiz)
Video Card: MSI Radeon RX 480 4GB Video Card  ($189.98 @ Newegg)
Case: DIYPC MA08-BK MicroATX Mini Tower Case  ($24.99 @ Newegg)
Total: $757.81
Generated by PCPartPicker 2017-01-21 19:49 EST-0500
RX480 4GB>1060 3GB
Yes the S12II performs worse than the G2 but to be honest, you don't really need a G2 for this build thus the S12II is more than enough in this case (to be fair, it would be enough for a i7 7700K and 1080 build so...)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241357
Total: $757.81
RX480 4GB>1060 3GB
i would rather own what i piced togethere here, 512GB NVME storage man xD and i also used the S12II, its a great unit tbh
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241367
the MX300 SATA version is litteraly $2 cheaper, no reason not to get the NVME one seeing as it takes less space and preforms better
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241376
I decide to have some fun with it
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($188.89 @ OutletPC)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($46.99 @ SuperBiiz)
Storage: Hitachi 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card  ($580.66 @ B&H)
Case: Zalman T2 Plus MicroATX Mini Tower Case  ($25.99 @ SuperBiiz)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.97 @ Newegg)
Total: $1033.48
Generated by PCPartPicker 2017-01-21 19:55 EST-0500
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241385
Wut? We both picked MX300s...it's just that you used a M.2 form factor MX300 which is still a fucking AHCI drive... xD
M2 and Sata are connectors
NVMe and AHCI is the thing that determines speed...
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241393
yah but its a nicer formfactor that takes way less space and looks cleaner lel
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241412
Total: $757.81
RX480 4GB>1060 3GB
Get the red dragon to fit exactly 750 nicely? Please?
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241419
1 minute ago, nerdslayer1 said:
why would he want an nvme storage solution while sacrificing on other components.
its 512GB, i couldent really do much with the other components in terms of preformance whilst keeping the 7600K and a decent Z270 board
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241422
7700k an 7170 board also a 480 8gb is better than just fast storage.  unless he is video editing he won't know that big of a difference from normal ssds.
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241427
I literally just picked the first MX300 525GB SSD I saw...
Bananasplit is confused by how connector=/=interface :P
1 minute ago, deXxterlab97 said:
Get the rad dragon to fit exactly 750 nicely? Please?
8pin, dual fans, beefier looking heatsink...no
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241428
PCPartPicker part list: https://pcpartpicker.com/list/D6pKkT
Price breakdown by merchant: https://pcpartpicker.com/list/D6pKkT/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($344.75 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.88 @ OutletPC)
Motherboard: ASRock Z170A-X1 ATX LGA1151 Motherboard  ($89.99 @ NCIX US)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  ($50.88 @ OutletPC)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($67.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.55 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($376.59 @ Amazon)
Total: $1058.41
Generated by PCPartPicker 2017-01-21 20:05 EST-0500
revised build, less storage but more preformance
*EDIT*
Confirmed BIOS update, latest BIOS will work with all Kabylake CPUs OP
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241461
i can not conector today :P its 2AM, thats probably why. also did a revised build thats way better
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241468
Total: $1058.41
Any BIOS update confirmation?
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241484
if you wanna cheap out alittle:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($58.99 @ SuperBiiz)
Memory: Kingston 16GB (2 x 8GB) DDR3-1600 Memory  ($67.10 @ Jet)
Video Card: XFX Radeon R9 Fury 4GB Triple Dissipation Video Card  ($290.82 @ Amazon)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($59.89 @ B&H)
Total: $871.66
Generated by PCPartPicker 2017-01-21 20:10 EST-0500
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9241495
i should check that but im pretty sure all ASRock boards should get one, il go check that now and get back to OP
Builds:
https://linustechtips.com/topic/726650-help-with-my-new-pc/#findComment-9243697
