a 1080p 144hz monitor
sheikhrehab7
please prescribe me an 1080 p 144 hz monitor 16:9 ratio ips panel... budget ($200)...
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig:
CPU: Ryzen 7 3700x
Ram: 1x16gb DDR4, 2x8gb DDR4
Storage: 1tb nvme ssd
GPU: gtx 3080
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: ducky one I | I SF
Mouse: gpro wireless | glorious model o2 wireless
Sound : beyerdynamic 1990 pro | Monoprice liquid spark (amp) + topping d10 (dac)
2 minutes ago, hconverse02 said:
I'd say the Acer Predator GN (Whatever is at like 200$ on pcpp) it overclocks up to 199Hz
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
Lol how the hell are you going to notice the difference between 144hz and 199hz?  No modern game is going to show that many fps.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Siege shows me 200fps with a GTX 980... And how am I going to notice? I can notice the difference between 144 and 165, and 165, and 180, that's also asking why they even made 144hz instead of just using 120hz because "you can't tell the difference" and if so, why do you need 240hz compared to 180hz? Point is, you can tell, it's difficult, but you can, it also gives you a couple less ms between each frame, and for games like CS:GO it can mean life or death.
Specs v-v
Given that it takes several milliseconds (some say up to 100) for the eye to even process an image, I doubt that 2ms is going to make a difference in how well you play.
I'm well aware that there is a difference between 120hz and 144hz.  My point is that unless you have an incredibly high end build, you aren't going to be able to pull off 199fps on any AAA title.
12 minutes ago, SCGazelle said:
You mean this one? http://pcpartpicker.com/product/PmyFf7/acer-monitor-umfg6aab01
I'm pretty sure that does not go to 199hz. It is just 144hz. Do you have one or have a link?
I said it OVERCLOCKS to 199, and its rock solid stable.
Hmm, A GTX 1080 at 1080p, sure incredibly high end, but even a 970 at medium settings can do that
Specs v-v
Yeah, how do you know? I have never heard of someone getting that overclock.
A friend did it, and showed me the overclock. So I ended up buying it as well cuz 144 is for scrubs. And I got it to 199 as well. We might have been just super lucky, but it's worth noting.
Specs v-v
hmm. OK. I was just skeptical for a second
I would be too. But she turned on vsync and let csgo run at the 199
Specs v-v
