Fans run at 100% after CPU Upgrade- Dell Studio 540
Solved by comicsansms,
12 hours ago, TheRandomness said:Try again with a fresh BIOS... I think I had the same issue with my brother's rig but I can't remember how I fixed it
5 hours ago, oskarha said:Maybe my guide for the 771 mod on the Vostro 220 could help
I tried using the flashing utility used that oskarha used in their Vostro Mod, it worked, my computer now is running at a reasonable fan speed once again.
Thank you, I really appreciate you guys help.
