Audio-Technica ATH-M50X
MorganO
a couple questions
1. are they OVER ear?
2. they are around £120 on amazon right now is this worth the price?
3. can i use the mod mic with this if so which one?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
3 minutes ago, KOMTechAndGaming said:
a couple questions
  1. Yes
  2. Probably not. Really up to how much you like them.
  3. Modmics can be used with any pair of headphones. They have it's own wire and run a second line that can be clipped to your headphones' wire.
9 minutes ago, KOMTechAndGaming said:
a couple questions
1. Yes
2. Absolutely, these headphones are well known for being THE BEST headphones for its price point
3. Yes
11 minutes ago, KOMTechAndGaming said:
a couple questions
https://www.amazon.co.uk/Beyerdynamic-DT770-Pro-Headphones-Ohm/dp/B0016MNAAI/ref=sr_1_1?ie=UTF8&qid=1484781880&sr=8-1&keywords=dt770
Much better and cheaper...
Over ear
Yes you can use mod mic with this
