Recently, my work pc which is featured in my profile basically died, don't know what happened to it but it doesn't work anymore. This topic isn't about repairing it, it's about creating a new pc. The one featured below is the one i need comments on, Im still undecided on the case, mobo, and cpu - veering for a white nzxt case on this build, but if there are any other white cases with a psu shroud that look sleek pls leave it in the comments. There is no max budget for this computer as my work is paying :) MAINLY USED FOR PROGRAMMING - SERVER ADMINISTRATION - AND LOTS AND LOTS OF COMPILING - FASTER THE BETTER (NOT TOO EXTREME THO, NO X PROCESSORS FOR NOW, STICK TO K's OR XEONS)COLOUR SCHEME SHOULD BE WHITE AND BLACK
CPU: TBD
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($159.98 @ NCIX US)
Motherboard: TBD
Memory: G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200 Memory  ($134.97 @ Jet)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($164.99 @ Jet)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.66 @ OutletPC)
Video Card: MSI GeForce GTX 980 4GB Armor 2X Video Card  ($347.72 @ Amazon)
Case: TBD
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($88.89 @ OutletPC)
Case Fan: NZXT Aer RGB120 (3-pack) 61.4 CFM  120mm Fans Other recommendations would be nice ($74.99 @ SuperBiiz)
Monitor: LG 34UC79G-B 34.0" 2560x1080 144Hz Monitor  ($599.00 @ Jet)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard  ($135.00 @ B&H)
Mouse: Logitech G502 Wired Optical Mouse  ($59.98 @ Amazon)
Other: white cable mods
Other: monitor stand
Total: $3117.77
Generated by PCPartPicker 2017-01-13 16:36 EST-0500
I would try and fix it before I go get a new pc
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Just now, RKRiley said:
Phanteks P400S, another nice looking case. Or the Enthoo Evolv ATX, i think that comes in white.
it should be really clean - like corsair carbide or s340/h440 clean
What do you mean by "clean"? no stupid lines/edges/curves? both the p400s and evolv atx are like that :P
Or do you mean super simple rectangle box, all flat sides?
already tried - seems like everything is shorted out - psu is dead - cpu and mobo too - storage also doesn't work for some odd reason and the ram didn't work on another system - besides my company's paying and i only pay for half and get to keep it - so it's a win win
nothing that looks like the front of the phanteks luxe - also, i would prefer only glass on one side so my shoddy cable management doesn't get seen
download.jpe
Get a 1070 or a 1060 over that 1080, its price isn't good.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
not really into gaming - the gpu is really for aesthetics - i might just get the asus dual 1060 or 1070
i7-6850K and an MSI X99 SLI PLUS, which I think would look pretty good with the other components. Or you could wait for Ryzen benchmarks.
Also, have you considered M.2 storage?
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
download.jpe
Eh the s340 is probably your best bet then. I'm very happy with mine and how easy it was to build in.
Or even the H440 if you want a bigger case.
CPU: Intel Xeon E5-1650 V4 3.6GHz 6-Core Processor  ($601.99 @ SuperBiiz)
Motherboard: Asus X99-A II ATX LGA2011-3 Motherboard  ($232.21 @ NCIX US)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory  ($175.99 @ Jet)
Case: NZXT S340 Elite (White) ATX Mid Tower Case  ($89.99 @ NCIX US)
Case Fan: NZXT Aer RGB120 (3-pack) 61.4 CFM  120mm Fans  ($74.99 @ SuperBiiz)
Total: $3379.39
Generated by PCPartPicker 2017-01-13 16:45 EST-0500
i would get a samsung m.2 drive - sure, the storage isn't the issue its just a placeholder - i just clicked on the first i saw - but the important part is the case, cpu, mobo and the case fans - hovering between thermaltake, nzxt or corsair
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($349.75 @ OutletPC)
CPU Cooler: Silverstone TD02-LITE 92.5 CFM Liquid CPU Cooler  ($73.99 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($148.64 @ Amazon)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  ($249.99 @ B&H)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($279.89 @ B&H)
Total: $3068.71
Generated by PCPartPicker 2017-01-13 16:49 EST-0500
Total: $3068.71
don't think u got the memo - 4 cores ain't gonna cut it need at least 6
whats the price you want to stay around?(i know you said no budget but i dont want to make you something thats like double the amount your company wants to spend)
you don't get it, my company will spend whatever, just don't go too extreme to the point where it costs as much as a used car
If you want the monitors you had picked you can switch them out, but i think this will do better
CPU: Intel Xeon E5-2630 V2 2.6GHz 6-Core OEM/Tray Processor  ($728.03 @ Amazon Canada)
CPU Cooler: Thermaltake Water 3.0 Extreme S 99.0 CFM Liquid CPU Cooler  ($109.99 @ Memory Express)
Motherboard: Asus PRIME B250M-K Micro ATX LGA1151 Motherboard  ($104.99 @ Newegg Canada)
Memory: Corsair Vengeance LED 32GB (2 x 16GB) DDR4-3000 Memory  ($269.99 @ Newegg Canada)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  ($332.00 @ shopRBC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($88.98 @ DirectCanada)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($534.25 @ Vuugo)
Case: NZXT Phantom 530 (White) ATX Full Tower Case  ($139.98 @ NCIX)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ NCIX)
Case Fan: Phanteks PH-F140SP_BK_WLED 82.1 CFM  140mm Fan  ($22.99 @ Amazon Canada)
Monitor: Acer G257HU smidpx 25.0" 2560x1440 60Hz Monitor  ($360.99 @ PC Canada)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard  ($163.45 @ Amazon Canada)
Mouse: Logitech G502 Wired Optical Mouse  ($82.50 @ Vuugo)
Total: $3422.11
Generated by PCPartPicker 2017-01-13 17:16 EST-0500
Total: $3422.11
i've decided on the 6900k and the asus x99 deluxe - but i will be gettign the led ram
