Ubiquiti Unifi Pro Access Point
Solved by KuJoe,
I keep the POE injector as close to the router/switch as possible, otherwise you'll have a POE injector in a spot that will be hard to access and you'll need a power outlet nearby. If you need to power cycle your AP for some reason, it's easier to just go to wherever your router is and pull the single ethernet cable out of it rather than climbing into the attic.
I have 5 POE devices at the moment (2 cameras, 3 APs) so I use this POE injector that I have sitting on top of my 24-port switch. It makes it really easy to power cycle any POE devices and also lets me still monitor the devices with SNMP (compared to an unmanaged POE switch).
