Hello, I'm looking into building a new PC and i decided on my motherboard I liked an AsRock x99 Professional LGA 2011-3 Intel X99
But my question is which CPU do you think is better?
Intel Core i7-6800K 15M Broadwell-E 6-Core 3.4 GHz LGA 2011-v3   439.99$ US
or
Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz LGA 2011-v3  389.99$ US
And some good ram too I guess. I am a gamer.
https://linustechtips.com/topic/721488-could-you-help-me-linus/
or
5820K, it overclocks better and is cheaper.....
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184741
the 6800 has slightly improved IPC, thats what i know about them
Builds:
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184745
1 minute ago, helsing said:
No thank you i picked the board I wanted that wasn't my question.
I know but im asking why do you want X99?
You can get just as nice looking boards, on the cheaper platform, that will do what you want to with near enough the EXACT performance, for much less.
Just tryna help you save a couple 100 dollars.
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184832
If you're sure you want the X99 platform (more expensive with little/no benefit) then get the 5820K. it's cheaper and is almost identical to the 6800K.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184852
I like the HDD savor function this board offer's that the newer one doesn't as of yet. That way I can keep a back up hard drive in my case and not having it run 24/7 When i turned it on I'll have auto back up all files i have selected. Is what i"m really looking for.I always seems to misplace my docking station some where. But yes i have my reason's for wanting this board I'm picky on how they look as well ^^
I don't know any other mobo that has this build in automatically other wise you have to make your own special button.
No power running to the hdd longer life space its only going to be for back ups and I don't have to go looking for it.
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184894
Well if you want to stick with a 2011 v3 board then you are going to have to go with an i7 5820K or any other cpu that fits this socket (i7 6800K, i7 6950X, i7 6900K etc).
The i7 7700K (Kaby Lake) is on a different platform and uses socket 1151.
https://linustechtips.com/topic/721488-could-you-help-me-linus/#findComment-9184998
