[Experiment] Household materials as thermal compound extreme
Lord Nicoll
In this test, I really wanted to test the boundaries, and I did. Even the good actual thermal compound failed, although it lasted longer. This test was performed on an i5 3570k at a very high 1.4 Volts on a stock Skylake intel cooler (there was no way anything could cool this). While actual thermal compound seemed to be managing, after 2 minutes (most failed within 30 seconds) it too succumbed, which might have been the result of the cooler rather than the Thermal Compound. The results are below. Nothing I tested actually worked, but again, 1.4 volts was extreme, on a stock cooler was never going to work. I wanted to see could it last. I also tested single core stress tests and some of them lasted 10 minutes, Thermal compound, Tooth paste, WD40 and washing up liquid all managed to keep 1 core at a time under control, so maybe if you're stuck they could be used. The nice formatting text file is included.  If you think I should retest fairly or with a better cooler just flame away. The system that was used was
Intel Core i5 3570K stock clocks @ 1.400 Volts
8GB Crucial DDR3 1600
ASUS ROG Maximus V Formula
Intel stock cooler (for Skylake, it's a lot smaller)
AMD FirePro V5900
Some random Dell 350 watt PSU
Some Random 320GB Toshiba Drive
i5 3570k @ 1.400 volts stock clocks, stock cooler. Prime 95 small FFT for 10 minutes OR until 25% thermal trottling OR all cores at one point log.
	thermal paste		temp				status		notes
	No Thermal Paste	H:105°C (all cores) L:53°C	fail		all cores logged within 1 minute, test stopped.
	model polly cement	H:105°C L:47°C			fail		strong smell of glue, not very effective, +25% throttling, difficult to clean. only core 1 didn't throttle, at 99°C
	WD40			H:105°C  L:59°C			fail		instant failure and trottling
	petrolium Jelly		H:105°C L:53°C			fail		Throttling over 50% and 3 cores reached TJ max
	Strontium Toothpaste	H:105°C L:47°C			fail		works well compared to others, but still failed, test stoped at 50% thermal throttling, tested lasted almost a minute
	Magnesium Sulphate	H:105°C (all cores) L:50°C	fail		Test aborted after 1 minute, all cores throttled to 1.6GHz
	washing up liquid	H:105°C L:45°C			fail		At first did good, but quickly throttles and fails, but did better than some
	Metalic Acrylic paint	H:105°C L:52°C			fail		All cores reached over 100, two throlled before falling to just 1.4GHz, a pain to clean
	Plasterine		H:105°C L:54°C			fail		failure within seconds as three cores log, and trottles back over 50%
	aluminium foil pieces	H:105°C L:53°C			fail		instant failure with multiple cores throttling and over 50% clock throttle
	Gel Shaving foam	H:105°C L:46°C			fail		test quickly failed, thermal throttling caused clocks to fall 50%
	Actual thermal paste	H:105°C L:46°C 			fail		failure was much more controlled, fan kept up for 56 seconds before throttling began, test ran for 2 minutes and 13 seconds before throttling reached 50%, no more than 1 core reached TJ max at the same time.
temps.txt
Yours faithfully
Wow this is amazing. Though I would suggest changing format to
H:105 C L: 40 C
So that people doesn't get confused and thought you got negative temps
H:105 C L: 40 C
Possibly, that although to go to minus temps with a stock cooler would put all heatsink makers out of money.
Yours faithfully
3 minutes ago, Oshino Shinobu said:
No mayo? It's the best of the TIM.
I wanted to avoid food products for this one, there'll be a food and body fluids one later, maybe at a lower voltage, while a few runs at 1.4 won't do much, regularly doing it might.
Yours faithfully
Put mustard and ketchup later then
Oh boy do I hate those condiments, I might need my respirator for that (I avoided it when dealing with the noxious poly cement that actually made be pretty high and dizzy and gave me a splitting headache)
Yours faithfully
If anyone is interested at stock volts (in a room that is now 5-10°C colder) the max temps are under 75°C with Prime95 small FFT with actual thermal paste
Yours faithfully
I'm interested in tests with a cooler that can actually keep up, or with a lowered heat load on the stock cooler
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
I think all your experiment shows is that a CPU consistently fails at 105C regardless of thermal compound. A more scientific test: put a meth burner under a sheet of wood or non-flammable product with a hole cut for a CPU lid. Measure the temperature difference over time.
ψ ︿_____︿_ψ_
The fact that actual thermal paste failed suggests that maybe you should have used a bigger cooler.
Aerocool DS are the best fans you've never tried.
homemade heatsink? or could you try out the heatsinks you get with stuff like rasberry pi? the metal ones with fins
The results are "clipped" and so it's not possible to compare performance on the high end where it really matters.
Well, the cooler couldn't keep up but only actual thermal paste lasted more than 1 minute and 30 seconds, but none of them thermally shutdown (I was watching the whole time)
That is the TJ Max, but not the point of failure, a fail is when three or four cores all reach or exceed 105°C, clock speed fell below in this case 2.65 (some did this even though the core temps where at 80-90, that is why the clocks went down). I could use the stock cooler with a precision heat source and just change up the TIM but that is a lot of work and has other variables.
It failed because 1.4 volts is a lot and even a good cooler would have struggled, but the stock cooler held out for a little bit when it actually has good transfer, Thermal compound and tooth paste to name a few lasted longer and didn't throttle within a 10 seconds.
Yes, an info dumb or graph would have been a little difficult to display and process on a PC that is already being tortured. No core at any time exceeded 105°C though, so it stopped a complete thermal event shutdown.
9 minutes ago, wrathoftheturkey said:
lol. Even at stock, it'll throttle almost any mainstream processor in something like AIDA
Actually the i5 3470k at stock volts leveled at 75°C for all 4 threads in Prime95, maybe if you throw in memory and all the cache it might hit 80°C but it held just.
Yours faithfully
Could you give the recipe?
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
recipe for what?
Yours faithfully
Quote
Quote
body fluids
Oh god please no.
Adults are just kids with bigger wallets.
5 minutes ago, Lord Nicoll said:
recipe for what?
Fior the thermal paste. Like ratios and stuff like that
AXIOM
5 minutes ago, J. Hammond said:
Oh god please no.
yes, that was a suggestion, I'm em, not too keep to do that one actually.
Yours faithfully
OH, the procedure wasn't all that uniform, as some of the materials where more vicious, but on average, a pea of the globey stuff and usually about .25ml of the more liquid ones
Yours faithfully
  • 1 month later...
Yours faithfully
Perhaps these results are better?
Yours faithfully
On 1/10/2017 at 3:00 AM, J. Hammond said:
Oh god please no.
Yes, I did them, they where bad and actually killed that very system basically.
Yours faithfully
Yes, that's far more useful, if a bit disturbing.
