I want to build a new PC for my Mom as her old laptop finally gave up. Can someone help me choose some parts I should get?
I have an old Dell Studio XPS 9000 pre-built PC that I plan on using, but it's near-bare with almost no parts. I'm looking for:
  • A decent motherboard (upgradeability isn't needed but would be great to have)
    • Compatible with a Radeon HD 6450
  • An SSD (for Windows 7 / Windows 10)
  • A hard drive (1 TB is more than enough)
  • A good CPU (maybe an i5, i7, or an AMD CPU)
  • I'm not sure about RAM. 8GB DDR3 or DDR4? :/
If the price wouldn't go over $400 CAD, that would be great.
Thanks!
Edited by Jobinx
https://linustechtips.com/topic/720117-pc-build-for-my-mom/
I have an old Studio XPS 9000 that I plan on using, but it's near-bare with almost no parts. I'm looking for:
  • An SSD (for Windows 7 or Windows 10)
  • A new HDD (1-2 TB is perfect)
Thanks!
why do you need a 2 tb hdd ?
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168699
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($149.25 @ shopRBC)
Motherboard: Asus H110M-C/CSM Micro ATX LGA1151 Motherboard  ($78.96 @ shopRBC)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  ($57.99 @ Newegg Canada)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($63.99 @ PC Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($63.94 @ Vuugo)
Total: $414.13
Generated by PCPartPicker 2017-01-09 00:17 EST-0500
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168718
Total: $414.13
psu ?
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168721
1 minute ago, nerdslayer1 said:
psu ?
He never asked for a PSU on the original post.
Personal Desktop":
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168725
Just now, Jobinx said:
Awesome! I actually don't need the PSU or case as I'm re-using some old parts I have.
Can you get an HDD later then
This would be amazing for her
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($235.75 @ Vuugo)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($58.99 @ Newegg Canada)
Memory: Crucial Ballistix Tactical 8GB (1 x 8GB) DDR3-1600 Memory  ($55.57 @ Amazon Canada)
Storage: ADATA Premier SP550 120GB 2.5" Solid State Drive  ($52.99 @ Memory Express)
Total: $403.30
Generated by PCPartPicker 2017-01-09 00:20 EST-0500
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168731
Just now, nerdslayer1 said:
using a old psu is not really safe
It is a build that won't even carry a GPU with it, as long as it is from a respectable brand he should be fine, I have a storage PC running an Core2Duo with the same PSU since 2007
Personal Desktop":
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168733
well its not really a good idea to skimp on a psu.
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168739
Total: $403.30
I believe I have an old Hard Drive that I can re-use. Thanks for the suggestion!
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168742
5 minutes ago, deXxterlab97 said:
an i3 is faster than any amd
An FX83xx trades blows with an i3 6100.
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168744
Honestly, I don't think you need anywhere near an i5, and you can probably get away with a Pentium.
Same with the RAM, 4GB will be more than enough for what the system will be used for.
Why do you need so much storage space? Even a 240GB SSD should be more than enough.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168749
1 minute ago, deXxterlab97 said:
Yeah but not with FX 6300 above
Still, your post may be misleading.
https://linustechtips.com/topic/720117-pc-build-for-my-mom/#findComment-9168752
