First build ever! BSODs :(
Solved by Redicat,
2 minutes ago, DJ Joel Roche said:No overclocking was done, BIOS reads the 16GB of ram, so does windows. Thank you for the tips everyone! If the problem persists after I have removed the WiFi card, I will check the ram. Cheers
Why in the world that HAUNTED WiFi Card make multiple BSODs i never seen any thing like that
make sure to mark solved your own post
