Does motherboard need a wireless card for wireless printer to work?
Omie
I have an Hp Officejet 4500 g510n all in one wireless printer.
If I connect my printer to my wifi network via router, would I still be able to print from it with my new PC even though I don't have a wireless card installed in my mobo?
Like would I simply be able to just add my wireless printer from the add devices menu of the control panel in Windows 10?
Your computer itself doesn't need to have a wireless card, it can be connected to the router via an ethernet cable and if the printer is connected to the router by wifi, your computer should see it.  The printer will be treated as a network printer instead of one connected directly to the computer.
Your router is the central network hub that every wireless device you authorize and connect will interact with, and if your computer is connected to the router by wifi or ethernet, it will detect any compatible device that is on the same network.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
If your computer is connected to the router via an ethernet cable, then it should work. Everything is on the same network.
You just need to be connected to the same network (i.e. the same router), it doesn't matter if its through ethernet or through wifi.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
