Need help with GPU upgrade
Solved by Simon771,
2 minutes ago, kevinisbeast707 said:That's what I was worried about with SLI. But it'd be between two plain reference 780s. But I'm not too worried about power consumption.
Oh my bad ... It's GTX 780 in SLI not GTX 780 Ti.
GTX 780 is 30% behind R9 Fury
http://gpu.userbenchmark.com/Compare/AMD-R9-Fury-vs-Nvidia-GTX-780/3509vs2164
And I also saw that you were mistaken about the price 165$ for RX 480
R9 Fury is a winner here. It does have best performance out of all those cards that you mentioned. GTX 780 SLI would perform a bit better in SOME games, but would also cause problems in other games. So if you ask me, R9 Fury is your best bet, even if I'm not AMD fan and I prefer Nvidia.
