Search In
  • More options...
Find results that contain...
Find results in...
G4400 gives mouse lagging issue when downloading
Go to solution Solved by 79wjd,
A G4400 should be more than capable to download something without breaking everything.....something funny is going on. I'd run a stress test on the CPU, RAM, and on the storage to make sure there are no issues there. Then I'd run an antivirus and anti malware. I'd also try a wired keyboard/mouse. And if that turns up negative, then I'd reinstall windows and make sure everything (including drivers) was installed correctly.
Also, why are you using an HD5450? The G4400's iGPU is good enough for what you're doing (unless you're running more than two monitors).
Finished building a budget system yesterday, with an Intel Pentium G4400
A little bit of disappointment, when I was downloading software like Google Chrome, Skype, and Microsoft Office.
The mouse was lagging so much that I cannot navigate smoothly. However, it has no problem when it was not downloading things. I checked CPU Utilization, sometimes it has spikes up to 100% on the CPU
I am using Logitech MK270 Wireless mouse and keyboard, I checked with Device Manager and made sure the software for the mouse is the MOST updated one.
Not too sure what causes the lagging, but it feels like the G4400 is not capable to operate when downloading software. Anyway to fix this? Will overclocking the G4400, giving it more processing power fixes this slowness while downloading issue? Does this has anything to do with Windows 10 updates? But I have not experience this slowness problem while downloading with my i7-4770K system though.
System Spec:
Intel Pentium G4400 at stock
AsRock H110M-DGS
Kingston HyperX Fury DDR4 2133mhz 2x4GB
AMD 5450 1GB video card for display only
Corsair CX430
Intel 530 Series 180GB SSD
Windows 10 Pro
Thank you for help.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
The MK270 combo tends to be kind of funky. My sister has one and it will just randomly lag to hell and back.
The PSU tier list + cultists are a joke that nobody should actually take seriously
Main rig on profile
Zephyrus - Windows 7 side rig
AMD Athlon II X2 260 (undervolted to 1.225v w/ CM 212 EVO), 2x2GB 1333MHz CL7 HyperX, Asus M4A77TD, 120GB 840 EVO, 250GB Seagate Momentus 5400.6, EVGA GTX 960 SC, Enthoo Pro, Corsair CX750M, Gigabyte GC-WB867D-I w/ Centrino 6300, Windows 7 Ultimate 64-bit
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB (Falcon w/ busted laser), XB1X 1TB, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB
but the mouse only lags when i was downloading software, otherwise it is smooth.
It could still be an issue with the mouse. You should try a wired mouse (or at the very least a different mouse) just to be safe.
PSU Tier List | CoC
insert shrug here
Only thing I really can suggest is setting Windows' power mode to performance and not balanced.
Main rig on profile
8 minutes ago, djdwosk97 said:
A G4400 should be more than capable to download something without breaking everything.....something funny is going on. I'd run a stress test on the CPU, RAM, and on the storage to make sure there are no issues there. Then I'd run an antivirus and anti malware. And if that turns up negative, then I'd reinstall windows and make sure everything (including drivers) was installed correctly.
Thanks for the suggestion.
I am using the HD5450 for the HDMI port lol ... the AsRock mobo is too low end that it does not has a HDMI port.
I will try that
