Cheap case + cheap power supply
Solved by quan289,
10 hours ago, Kebogu, said:A local store is offering this model for $45 and it seems too good to be true, what do you guys think?
http://www.agiler.us/Productitem.aspx?ID=452
This is probably the PSU that's coming with the case, as the only other 600w unit is made for a HP computer (may have proprietary connectors).
Modern day power supply have most or all of its rated power on the +12V rail. As you can see in this unit, it only has 16A on the +12V which is 192w. That's, at best, a ~200w unit if we go about that. Also, the presence of the negative 5V rail shows that this PSU is design over a decade ago.
It is highly recommended that you invest in a proper, modern day power supply for your system.
