How many watts do I really need?
Fey
I've went to few shops and they keep telling me that I need around 650W of PSU, but most PSU CALC website told me that I just need maybe around 350W.
My build is similar to the $1000 PC build on Holiday's buyer guide 2016 video, and linustechtips just chose a 500W PSU.
Should I just go with 500W or go with what those shops telling me?
My build:
i5-6600
MSI B150M Mortar
Kingston ddr4 8gb ram
ZOTAC GTX1070 AMP Edition
WD 1TB
Tecware F3
Links:
My results of watt needed : http://outervision.com/b/e1qAjX
Linustechtips Holiday's buyer guide 2016 :
2 minutes ago, Fey said:
A 1070 and locked i5 will realistically never use more than 250W.
For you a Corsair RMx 550W or EVGA GS/G2/GQ/B2 would be solid. Of those 550W is the lowest wattage you can buy.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Well you only need like a decent 80+ power supply from a reputable brand that is over 400watts. Id suggest 500W 80+ Bronze minimum, if you want your PC to look great though for a decent fully modular power supply.
You'd be fine with 500-550W. Just get a power supply that is one of decent quality.
Cue the LTT PSU Tier List. Anything from T1-T3 is fine.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
I agree, although your system will come around 400w, you should have a bit of head room.
ok thanks for all the replies.
the shop that I went don't sell Corsair or EVGA PSU :/
How's Aerocool KCAS 500w 80+ Bronze 3 Years Warranty, it's quite cheap compare to others:D
A quality 450w would be good for that system. Do you have a link to the store you are buying from? Also, what your budget?
I don't think they have a website, but I have their pricelist. RM is the currency of my country and it stands for Ringgit Malaysia.
So you have a budget of around 200 MYR / 45 USD? I would need to do a bit of research on that Aerocool as it's a 230V only, budget PSU (not available where I'm from), but I don't have time to do so.
If you can spend about 100 MYR / 22.50 USD more, the Seasonic S12II-B 620w would  be my recommendation, as it is a solid budget unit; although, it is overkill for your system. See if you can ask them if they have the 430w or 520w model at a cheaper price. Maybe the list isn't completely updated.
42 minutes ago, Fey said:
- Snip -
Either of those Seasonics are great.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
How much are you willing to spend?
Power supplies that are decent (e.g. Tier 3/4 and better), from low price to high...
  1. BeQuiet! L8 600W
  2. SeaSonic S12 II 620W
  3. CoolerMaster G550M
  4. SuperFlower Leadex 550W
  5. SeaSonic M12 II 620W (semi-modular verion of the S12 II)
IMO either the SeasSonic S12 II, or the Superflower Leadex Silver -- quality AND price wise.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
How's Aerocool KCAS & Silverstone Essential I wonder:o
I'll try to ask for SeaSonic S12II 520W
If not, I'll choose between BeQuiet! L8 600W & SeaSonic S12II 620W
seasonic is great
