So I decide to so my very first custom loop and I spent the last 4 hours intaslling a gpu block and half a CPU block then I realized: I bought a ek slim 360 radiator and the thing is way too long. I originally was gonna put it in the top of my case but the thing is so long it almost sticks out of the drive bays. I can't return it and also can't replace it with a smaller radiator so I need some way of putting it somewhere. Anyone have any ideas? I can't get a new case either.(FYI case has a 240 rad mount at top, 120 back, front and bottom) Also I need to finish the loop by Sunday as I will be busy next week.
Alnair (Main PC):
CPU: i9-7900X with EK Supremacy RGB and SE 360 radiator
RAM: 32 GB Trident Z RGB 3000 MHz
MB: Gigabyte X299 Gaming 7
GPU: GTX 1070 Founder’s Edition
PSU: EVGA 850 G3
SSD: WD Blue M.2 1tb, Sandisk SSD Plus 1tb
Mistle (NAS):
CPU: Pentium G3258 with stock cooler
RAM: 8GB HyperX Fury DDR3 1600 MHz
MB: MSI H81M-E33
GPU: Intel integrated
PSU: 500w Cooler Master
HDD: 2 x 2tb WD Red in RAID 1
Armakarth (NAS/3D modeling station/my old computer)
CPU: i7-4790K with Hyper 212
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
SSD: Sandisk SSD Plus 240GB
HDD: 2 x 2tb WD Red in RAID 1, 2tb Seagate Barracuda, 1tb WD Blue
The Pizza Cooker (server):
2x quad core 2.66 ghz Xeons
16gb DDR2 FBDIMM
https://linustechtips.com/topic/701033-slight-miscalculation-rad-length-need-help/
Find a way to get tubing out of the case and mount it somewhere externally.  I don't have any radiators in my case, they're all in the table that the case sits on
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
What case is it? May be possible to mount with modding
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Unfortunately the USB thing is in the way so modding won't help
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
What case is it lol ?
Ryzen Ram Guide
Hilariously enough, I have no clue what brand or case the case is because I removed the company's logo so I could stick on an MSI sticker?
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
Ok well an idea, could you buy a new case ?
Ryzen Ram Guide
Post a picture of the case.  We may be able to help you find the make/model.
Buy a new case... you have a wasted rad otherwise, unless you could sell it. But it sounds like it may not be the best case choice for watercooling anyway, as if you were only going with one rad for a CPU + GPU, you really don't want less than a 360. You COULD use a 120, but then you're having to buy a new rad anyway. You can do it off one, but would need to be a 360.
Clearly a tall order to finish the loop by Sunday, as you either need to go out and buy a new case, or a 240 and 120 rad. My recommendation, get up early, go buy a new case that can take a 360. Loop will be much easier to put together with one rad anyway.
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
Yay! Apparently I can put the radiator on top of the case blowing air in and it doesn't look that bad
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
If you could place it on top and have the air blow out that would perform better. Heat rises and you don't want to make the air inside hotter.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Show us pictures... the internet will be the judge and jury on this matter. ;)
Here: (kinda messy, still leak testing)
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
Also does anybody know if high cpu temps right after installing custom loop is normal? (Air hasn't bled out yet I don't think and I only turned on PC to check to see if everything is working)
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
What do you mean by high?
Like 70 degrees idle
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
Oh wow.  You'll want to make sure to get the air out of the loop, but I doubt that you have enough to cause that high of an idle temp.
Make sure that your block is mounted well and that you have adequate TIM.
Check to make sure that your pump is circulating as well.
Yeah... I'm gonna try reinstalling the CPU block because running heaven my gpu got up only to 35 degrees while my CPU was 80 idle
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
Edit: WHAT AM I EVEN DOING
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
1 minute ago, done12many2 said:
 You tell us.
Just edited it I didn't peel off sticker on CPU block xD
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
Many people have been there and done that...
2 hours ago, done12many2 said:
I would have never posted that on the internet.  It never forgets. Ha!
Better than drilling holes in a mobo hahahahahahaha.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Apparently putting the radiator and pump on top of my case was a horrible idea because today I had a friend helping me and he told me that I was blowing hot air into my PC and I should put the radiator behind my PC where nobody would see it and then he tried to move the radiator and I didn't tighten the cap on the reservoir and coolant went everywhere and got inside my fans and all over the back and too of my motherboard and I spent the rest of the day cleaning up the huge mess and of course I tested the fans and some coolant had gotten into the radiator and it blew coolant all over my walls. I don't think I can use my PC for a week until everything is dried out and I get a new pump cable because the one I have is defective...
Starting to regret liquid cooling I coulda bought a laptop that could actually run task manager (current laptop task manager uses 30% CPU)...
Plus I'll have to game on my server which has no gpu (well I have a spare gpu but it doesn't fit)...
Alnair (Main PC):
PSU: EVGA 850 G3
Mistle (NAS):
MB: MSI H81M-E33
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
16gb DDR2 FBDIMM
I've got to be honest here.  You've made quite a few big mistakes along the way. You could have probably benefited from doing more research prior to starting, but I too understand the need to just make it happen.
I'm sure that you've learned a great deal by doing it yourself so it's not all a loss.
In the past, I forgot to tighten a res tube to its base resulting in a disaster once I powered the pumps.  Coolant everywhere and on every major component in the build.  Luckily, nothing was damaged, but my pride.  It turned out to be one of my most trouble-free builds.  I wish I would have kept it.
As far as your current laptop and Task Manager, if this is an ongoing issue that you can't resolve, start clean with a fresh Windows install and go from there.
