Keyswitches for stuff like minecraft and schoolwork?
KSores
People can say what switches they like but the switch 10000 people like may be the switch you don't like.
Brown is a good go to switch. Same with red. Go to a BestBuy or W/E stores you have around and push some keys.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
Depends which you like. I personally really like blues, although browns are okay too. I like having tactile feedback that the key has activated. Best way of finding out which you like is going to a store and trying them.
keyswicthes (and keyboards in general) are personal preference.
it's basicly like you're asking us what's the best kind of carpet to put under your desk. for all the advice we can come up with, nothing is gonna beat going to the home decoration store and putting your feet on some carpets so you can pick what feels the most right.
I like browns, they are somewhere between red and blue.
But it's personal opinion, so the best thing you could do is to test different switches yourself
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
To answer your actual question;
Since you don't play any competitive fps or similar, the impact on gaming ability is negligible. Therefore you should be basing your switch choice on how it feels to you rather than "best for X and Y"
Generally, there are two main types:
Linear (reds, blacks etc) - these are often preferred for gaming because the lack of an actuation leads to easier double taps etc
Clicky (browns, blues etc) -these are generally preferred for typing because people enjoy an actuation point
Honestly though, you can game and type on any switch and still be fine. Do some further research or listen to the recommendations above.
52 minutes ago, KSores said:
wahat are good cherry Keyswitches for stuff like minecraft and schoolwork?
Try keyboard out IRL.
Logitech G910 Orion for the win.
