Water Cooler doesnt fit in my case
Solved by TidaLWaveZ,
You need a 240mm rad, you've got a 280mm(h115i).
Your case has top support for up to 240mm so that's the best you can fit without mod.
240mm and 280mm don't really have a performance gap, so the easiest solution is to grab a 240mm rad like the h100i.
Featured Topics
gamingandblaming ·
Posted in Cooling0 -
SuperFlower ·
Posted in Displays1 -
Prehistoric ·
Posted in CPUs, Motherboards, and Memory2 -
Phenz ·
Posted in CPUs, Motherboards, and Memory1 -
1
sunze ·
Posted in Troubleshooting1 -
LiterallyDiego ·
Posted in Phones and Tablets0 -
ShadeBorderlands ·
Posted in Programs, Apps and Websites2
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
