Differnce between US and UK keyboard layouts?
How easy it to adapt from a UK to a US keyboard because I am planning on buying
MasterKeys Pro S Mechanical Keyboard with Intelligent RGB, Cherry MX Blue Switches, Multiple Lighting Modes and 80% Layout
But it is in US layout and I'm from England. However they don't sell the UK layout in MX Blues. Can I just replace a few key caps and it will work fine?
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/689666-differnce-between-us-and-uk-keyboard-layouts/
why not jsut get a different keyboard? The clicky ones are overpriced anyways
Because I need one with 10key-keyless
and I love the blues so much I couldn't get anything else.
GPU: RTX 2080 Super
The only differences AFAIK are that the " and @ are switched. No £ symbol maybe.... and possibly the ? and ' are somewhere else too, but can't say for sure... I know for definite about the " and @
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
http://uk.pcpartpicker.com/product/gVwqqs/cooler-master-keyboard-sgk6030kkcm1us
http://uk.pcpartpicker.com/product/tLZQzy/cooler-master-keyboard-sgk4000gkcl1us
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
2 minutes ago, wrathoftheturkey said:
son.......... no, son.
http://blogs.transparent.com/english/differences-between-the-us-and-uk-computer-keyboard/ although I have an MSI laptop that's US and has an Alt-GR key, this seems to be right
so if I had a US layout and bought a few kepcaps to move around could I essentially turn it into UK?
GPU: RTX 2080 Super
I find the quickest way to tell by looking at the return button, if it is single or double height. I ran into this problem before, and at the time the Corsair RGB ones I were looking at are in full UK layout, but all the marketing pictures only show the US layout which really confused me. More recently I bought a Logitech Prodigy whatever it is called, and can also confirm they do the proper UK layout. My MSI UK laptop does have the US style layout.
GPU: RTX 2080 Super
It isn't so much about the mapping of the keys, you don't even need to change the keycap if you select the UK profile and press the button where it should be regardless of the marking. The biggest difference are the physically differently placed keys. Decide if that is likely to be a deal breaker for you. For example, I expect the \ key next to left-shift, and on a US style keyboard it is elsewhere and annoying, regardless if they put the £ symbol on the correct location.
Guess I'll just have to keep looking or settle for browns
GPU: RTX 2080 Super
Software wise nothing.
The difference is 5 different key caps which you can replace for under $10,
Also note, the UK keyboard is layout usually is ISO (vertical enter key) and US is usually ANSI (horizontal enter key), but that doesn't change much.
do you really need it to be TKL?
Old Rig
TKL?
TenKeyLess
Old Rig
I was in the same predicament as you buying virtually the same keyboard from CM, it looked like the US layout online on the UK/EU store... but when it arrived it was actually in the UK layout :)
I believe they just use the same stock photos on all their stores regardless of country. I am 99% confident that if you bought it, it would have the correct keys.
I would call their customer services and ask.
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
