First off, I'm not an experienced PC builder. This is my one and only build. I may be worth mentioning that all components are coming from an Asus RoG Tytan computer. (I switched case in hope of reducing the noise level)
The specs are the following:
  • NZXT H440 Razer Edition
  • Intel i7 3770K cooled with an AIO liquid cooler from asetek and overclocked to 4.2 GHz (from original 3.5)
  • NVIDIA GTX 680
  • Creative SoundBlaster Z Sound Card
  • 256GB Samsung SSD
  • 1TB Seagate HDD
  • 3TB WD Red HDD
The reason why I'm posting this here is, that even after switching case, my build is still making too much noise. It's very noticeable when turned on and even disturbs me from working sometimes.
I have 5 fans installed in the case: the three pre-installed fans in the front of the case, and one on the top. All of those are sucking air in. There is also one fan blowing out air through the radiator of the asetek cooler, which also is the CPU fan.
Can anybody give me tips on how to decrease the noise level of my build without risking the temperatures to go up from my usual 40-60°C (under load)?
(also don't bother with the red led, it's coming from my sound card and I didn't have the time to remove it yet)
https://linustechtips.com/topic/687423-build-is-too-loud/
What kind of fan control are you using (if any)? If you are not, use some!
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824642
Any reason your sound card is in the primary slot and your GPU is in the secondary? :D
Is it the GPU or the CPU cooler being too loud? I suspect it's your 680 as looks like it's being cooled by a reference cooler which is probably why your PC is so loud. Reference coolers=junk (except AMD's wraith which is about as good as a 212 evo).
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824643
It's the 680. You could buy fans that are known to be quiet like Noctua or Silent Wings from Be quiet for the radiator and case fans. Use a fan controller like MSI afterburner to set a custom fan curve.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824644
Just now, Chesta said:
How can I check that? I just connected the PSU to the fan hub in my case and left it like that
your fans are probably running at 100% all the time then if you only connected the PSU. do you have the hub connected to your motherboard in any way?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824663
I doubt it's my GPU, because I can hear it when I'm gaming or rendering something, but not when my computer's idle.
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824665
Custom fan and pump profiles is really all I can suggest, I have a 240mm radiator, and I have my fans running around 800-1000 rpm idle and 1400-1600rpm while gaming and my pump is around the same, and my gpu's fans are completely off becuz maxwell+. And my CPU temps are 28c idle and 44c with aida64 and fur mark running. (Gpu on air not blower style @ 1670Mhz) still doesn't get above 60c.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824669
then your fans are just running at max speed... connect as many as you can to the motherboard so you can controll them, also why is the GPU in the second slot?...
Builds:
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824672
No I don't think so, at least I didn't connect it back then. I'll quickly check and post a picture of the hub
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824673
i have my fans running at around 350rpm and its super silent. theres not much you can do when the temperature goes up and the fans go to max speed except buy Noctua fans, but even they generate noise at max speed. You prob have too many fans on intake than you need
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824722
Have you identified which components are too loud?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824791
Yes, it's the fans altogether. I hear the CPU fan when CPU's under heavy load, and I hear my GPU when gaming or rendering. But the rest I hear all the time. So I guess it's the fans.
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824801
Does stopping the fans with your hands stop the noise?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824825
Yeah. But don't misunderstand, it's not like there's some abnormal noise - it's just the normal fan-blowing-noise, but it's too loud in comparison to "normal computers". I think it has to do with my lacking fan control. It would make sense that they spin at 100% all the time. How do I control them?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824848
What fans do you have and what header is each fan powered from?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824926
30 minutes ago, Chesta said:
Okay so I checked: FAN1 is coming directly from the PSU, the rest are the fans powered by it.
The one going upwards is the one on the top, the rest are the three fans in the front. The fans are just the standard included ones (FNv2 case fans)
As stated, FAN1 is the power supply coming directly from my PSU.
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8824951
This seems to be the case... How can I control my fans? Should I connect the "CPU Fan" connector to my Fan hub?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8827290
yes. that way it should be a lot quieter already. then if it still seems too loud you could always set the fan curve in your BIOS.
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8827303
That's just a powered hub and will run any fans connected to it at 100%.
You should connect your fans to something that can actually control fan speeds like your motherboard.
What motherboard do you have?
https://linustechtips.com/topic/687423-build-is-too-loud/#findComment-8829639
