I have been working a lfs project with friends we made a Working lfs already but one my friends wants us to start over and use BTRFS instead of EXT4 but i have never used btrfs before and i wanted know how would i go about making it like and what would be the commands for btrfs instead of the ones for ext4. help is really needed Thanks
https://linustechtips.com/topic/687052-i-need-help-with-my-linux-from-scratch/
Your favourite Internet search tool is helpful here.  From the Oracle Linux manuals:
https://docs.oracle.com/cd/E37670_01/E37355/html/ol_create_btrfs.html
Presumably mkfs.btrfs is on your system because you've built up the btrfs support tools (including kernel inclusions).   If you can't invoke mkfs.btrfs directly, you might be able to do it with a -t option, ie: mkfs -t btrfs with traditional mkfs
  • 4 weeks later...
thank you this helps
