im having problems since buying a new mobo my system boots fine but fails to load windows i turn it off and try again and it usually works don't know whats wrong never had this problem with my old mobo everything is 100% stable once i get into windows please help
https://linustechtips.com/topic/686932-please-help-loading-windows-problems/
Did you reinstall windows?
then wouldnt my copy of windows not work at all? im on the system im talking about right now... can i use the register key that i am using now? and i would prefer not too if there is another way around it cause my ssd is old and im worried if i write a large file to it it is going to fail
Yes, when you change your motherboard, it might happen, it might not, but sometimes you need to reinstall Windows, so it can recognize the new motherboard. About your SSD, use a program that can read S.M.A.R.T. data, and see how many TB have been written to the host, then, search on the internet for your SSD lifespan.
Thanks for the reply ill check and see if it's updated the mobo I'm using if not I will try a reg edit and force update it if that doesn't work I shall take you advice and see if I can even put windows on it again with out it dying by checking the smart data and the internet search of my ssd. Again thanks for the reply the first 2 people where pretty unhelpful
5 hours ago, Julian2000nl said:
- Uttam Yadav, Microsoft Tech Support.
Reactivation =/= reinstalling. Just FYI. Or if you don't know the difference, reactivation means one needs to log in to MS account or re-enter product key. Reinstalling means, well reinstalling Windows from install media or recovery media for laptops.
@KeenOn have you tried to repair Windows? Something like this could be because of update issues. If it hasn't been activated, it should still boot normally. Also what hardware did you change?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
14 hours ago, Julian2000nl said:
You need to reinstall if you have new hardware
It's some genuine copy anti-piracy protection bullsh*t
It's only an issue if somebody was stupid and bought the OEM version instead of the RETAIL version.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
That only happens when you buy the OEM version? I thought it was for all the version.
15 hours ago, Julian2000nl said:
Q: What happens if I change the hardware configuration of my Windows 10 device?
A: If the hardware configuration of your Windows 10 device changes significantly (e.g. motherboard change) Windows may require re-activation on the device. This is the same experience as prior versions of Windows (e.g. Windows 7 and Windows 8.1).
Only the motherboard makes a difference, maybe the CPU, but I think it's only the motherboard.
OEM versions are bound to first mobo they are activated on. Unless OS is Win7 or older, then some extra things are in play. As for CPU, Windows doesn't care.
