please help my poor lil' 1080
Dalynx
hey guys just a  post here to see if anyone wants to take a crack at it, recently my gtx 1080 has been deciding it would rather clock down to 1600 mhz than sit at its happy 2000, i then found out it only clocks to 2k when it feels like its actually needed, which is a problem as not many games really demand its true power, so it yawns and says i'll half arse it, although i know it shouldn't be like this, is there any way to fix its laziness or at least trick it into giving all it can, thanks everyone 1f642.png:)
Does it do this during benchmarks and stress tests too? If so it's most likely not stable enough to hold 2000MHZ boost state for long, try sitting it at around 1850 and see if it's still fluctuating as it is.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
I think this is the work of GPU boost. You shouldn't be hating this, in fact you should love it. It helps save power when not needed, thus increasing your game budget.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
na man its happy at 2k whenever it gets high usage, otherwise it won't rise past 1600, like the only 2 settings or 1.6 or 2 k at the moment haha
i wouldn't mind but its destroying my fps
Just now, SmashinMachine said:
set in nvidia panel in "Power management mode" from Adaptive to Maximum Performance. See what happens
no clue what that is but i'll give it a go haha
can ya help me find it :P
Oh okay so it's just based on usage. Yep that'll just be GPU boost, as well as any power management you have running in the driver panel.
it keeps ruining my fps though can i stop it?
1 minute ago, SmashinMachine said:
Here
thanks i've just done it, hope this works, brb off to test dayz
Give us an example? How is it ruining your fps? Every nvidia card does this?
dayz can hit as low as 40 fps where as before it refused to drop under 90 usually
you fuckin genius
11 minutes ago, SmashinMachine said:
Here
thanks the fix seems to have worked perfectly at least on dayz
