Will a mechanical hard drive be bottlenecked by Gigabit Ethernet?
Solved by mariushm,
If it matters, here's 4 of my 5 drives .. the last is a Sandisk X400 the boot drive, and note that the graph is not that representative because the defaults for benchmark is 64 KB blocks of data read from drives, which works fine for regular hard drives but not so much for SSDs.
By raising the block size to 8 MB, i get up to 400 MB/s .. still a bit below than what a Sandisk x400 ssd should do but good enough for me.
So a HGST NAS 4 TB with 18k hours on, an older WD green with 23700 hours of operation and an even older 1 TB WD Black with 52340 hours of operation or about 6 hours of 24/7 running and then the sandisk x400 ssd.
