Monitor calibration
derpylt
Hello,
So I've bought an Asus MG248Q monitor and I can tell that default calibration is really bad! It looks both sharp (looks like text and animation corners are cut off), and overall bad experience for my eyes.
Can you guys post your monitor settings like sharpness and brightness and I might try yours and see if any of that helps.
I think there are some options in Nvidia Control Panel too, so if you could post settings for best quality I would be very happy.
derpylt,
There isn't some generic setting for monitor that everone would like it.
Best advice? Just play with those settings a bit and see what you like.
Also keep in mind that when you switch from one montor to another, you will always need some time to get used to it.
As I said, play with settings a bit and if you do something "stupid", just reset monitor to factory settings and you can derp around again.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Are there any settings in Nvidia Control Panel that I can do to smoothen it out?
