Need help painting my headphones
CardinalHunter
7 hours ago, CardinalHunter said:
uhh come again
I mean, that ring should unscrew... In that case, just unscrew it, paint it, and then screw it back in.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
11 hours ago, CardinalHunter said:
uhh come again
The easiest would just be to mask off the entire ring around the outside but if you wanted to paint the exterior portion of the ring you would do it from the inside to not get paint inside.
have u seen the pictute the ring is fixed on that point
Not what it looks like to me, based on the photo you posted.
Hey! New SIgnature!
well if there even was a screw I wouldn't even know how to take it apart
soz but i still don't get u could u possibly elaborate further
Just mask off the connector so no paint gets inside basically, be creative as long as nothing gets in there and affects the electrical connection your good.
If you don't get what he's trying to tell you, I'm doubting that you should actually be painting them.
Hey! New SIgnature!
I think I get it now so I can just put a layer of masking tape above the connector can cut the shape of the ring out? I don't know how to properly mask the things off the make sure no paint gets into the connector
A second long as you stick it down so the edges are firmly in place over top of the edge you shouldn't have an issue with paint seeping down into the connector.
uhh why do i feel like i got a used one i just found a strand of hair in the driver, I mean can plastic when i'ts not even sharp and I haven't really got to use it it's been sitting in the box like wtf
