I am about 2 months away from my first build. I am pretty sure i would like to stick to the stock intel CPU cooler. I don't plan on overclocking, if i do i will buy another cooler.
I don't really want to install an aftermarket CPU cooler, as they look quite difficult, especially on my first build.
What do you think i should do ?
Is a stock CPU cooler good enough ?
Build - http://uk.pcpartpicker.com/p/1QGFN
Thanks
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/68006-thoughts-on-stock-intel-cpu-fan/
To be honest, an aftermarket cooler like the Hyper 212 EVO (Around $20-$30) is easier to install than the stock fan.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
Dont use the stock cooler. It barely manages to keep the cpu cool @ stock and it gets loud... reeal loud.
Get this instead: http://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
Not really harder to mount than the stock cooler - just follow the instructions.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
Intel would not include a heatsink with the CPU if the heatsink was not capable of dissipating enough heat for the CPU to operate safely. It will perform fine, Aftermarket heatsinks for the most part are easy to install, but if you are worried about it the intel cooler will suit you just fine.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
how hard is it to push 4 pins through the motherboard? it literally takes 5 seconds to mount the cooler and plug the fan in.
No backplate, just 4 plastic pins that you push through the mounting holes around the socket, seriously it's easier than breathing.
$%28KGrHqF,!qkFCSkLMNlcBQ2E0ZsCCQ~~60_35
As far as my knowledge goes if you go intel you can stick to the stock cooler. It's pretty quiet (Unless you oc and stuff like that). My scool upgraded there pc's lately and they use stock coolers. And the pc's are silent.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
stock cooler was fine for me it kept my cpu cool (under 90c) with overclock around 4.3ghz running ibt but i have 3570k
Follow these instructions to the letter, do not deviate from them or the universe will cease to function:
1. Open CPU box...remove CPU gently and place to the side.
2. Remove stock cooling solution and THROW IT THE F@#K away, far away....don't look where you threw the evil thing...in case it calls you.
3. Because you stated no OC...the Hyper 212 Evo is good enough.
Humor aside....stock is "bleh", some peoples get by with them, others don't.  For a few extra duckies, the Hyper 212 Evo is a good buy and will keep your temps acceptable (or go stupid crazy if your case allows it and get a 140mm cooler and never worry again :lol: :lol: :lol: :lol:
That is until the water cooling bug hits you....good luck. :blink:
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
I avoid these things like the plague, back in the socket 775 days you would see these suckers bending and warping motherboards from the amount of pressure that they put on the socket.
That may have been the case back then I wouldn't know but it isn't like that now. The stock cooler works people, it won't let your CPU go into meltdown it won't snap your board and it's so easy to install that calling it easy makes it sound too hard. Intel would not include the thing if it didn't work.
Wait if you're not overclocking why are you getting a 4670K and a Z87 mobo?
I might OC later
Use it until you can afford an aftermarket one, personally I wouldn't OC with one if you paid me.
I've since taken the heatsink off of mine and I am turning it into an Ironman chest piece.....
I'm the one who overclocks.
CPU: i5 2500k w/CM Cooler Master Hyper 212 EVO OC'd@4.2GHz RAM: Corsair Vengeance 8GB  MOBO: Intel Burrage DP67BG GPU: MSI GTX770 Twin Frozr 2GB HDD: 2x Seagate 2TB Barracuda PSU: Gigabyte ODIN 550W
I am going to do that when i get another one :)
I would get a Hyper 212 Evo. This is a pretty good tutorial imo: http://www.youtube.com/watch?v=BWG73Mom4cY
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
I'm sad that my Hyper TX3 got damaged when I dropped it and it was bending the living s*** out of my mobo. However, the stock cooler does insanely well for how little it is, and having the fan set at 50%. The load temps are right around 120F, which is right in line with my IceQ video card.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Thanks
A stock cooler is fine!(just remember not to overclock to much, or you'll crash) but you should try out the Cooler Master Hyper 212 EVO.  It seems quite simple. And provides great cooling.  And Might I ask why you got the 4670k? because you could have saved money, the "k" is for overclocking.  You could have saved money by going with one that cant overclock.
