I assume my cpu is bottlenecking and making my 1070 act like a potato?
Go to solution Solved by johnwshek1218,
the geforce experience drivers should have the gpu drivers as well, like if you went to nvidia.com or searched google for gtx 1070 drivers you would then have been brought to a page where you can search for drivers for your gpu in this case 1070, and then hit i agree and download, and geforce experience is included in that download, if you are unsure, when geforce experience opens, navigate to the drivers page with experience, and it will tell you if you have the latest drivers installed or not, and you should be in regular mode when installing not safe mode.
Do me a favor, go run a cpu heavy program like aida 64, cinebench etc and look at your cpu usage and tell me the results. If it fluctuates, it's a motherboard vrm issue, you could solve it by getting a vrm heatsink, placing  fan to blow over it, or getting a new motherboard.
Just now, johnwshek1218 said:
your cards in the right slot, and yeah id re install the drivers, it usually helps.
ok, so I installed ddu, so just open that and itll do that for me?
Here are my specs:
  • CPU: Intel - Core i7-8700K 6-Core Processor OC @ 5.0ghz
  • Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
  • Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard
  • Storage: Western Digital - WD Blue 1TB 2.5" 5400RPM Internal Hard Drive
    • Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
    • WD 4TB Black - Passport
  • RAM: Corsair Vengence RGB 2x8 RAM
  • Graphics Card: MSI - GeForce GTX 1080 Ti 11GB Founders Edition Video Card
  • Case: Corsair Crystal 460x
  • Power Supply: Corsair - CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply
  • Operating System: Microsoft - Windows 10 Home OEM 64-bit
  • Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor
  • Keyboard: Corsair K70 Mk II
  • Mouse: Corsair - SCIMITAR PRO RGB Wired Optical Mouse
  • Headphones: Bose QC 35 II - Active Noise Cancelling Headphones
and dont be sorry, asking is how you learn, experience and doing it is knowledge, and knowledge is power, we where all in your spot at one time, and thats why we are here to help, so just keep asking and learning, we are here to help.
is it supposed to look like this?
Here are my specs:
Also my intel driver installer kinda stopped finding drivers, so I'm not sure whats up with that.
Here are my specs:
yes whenever you uninstall graphic drivers you usually want to be in safe mode
ok ill start it in safe mode
Here are my specs:
the intel driver tool i dont usually use, i just download all the chipset drivers and every other driver from the motherboards website under support. and do you have a laptop or another computer that you can use the forum as your troubleshooting so if something happens you can still communicate?
yes I do. And so now geforce experience has reinstalled all the drivers, but now do I need any other drivers or just the geforce ones?
Here are my specs:
good news, things are working again, I have every setting at max and extremely rarely drop below 60 fps!
Here are my specs:
good shit man, good for you, yeah drivers usually are the number one reason why graphic cards are fishy, the hardware is only as good as the software, and another reason why amd cards are uh ehhh.. because the implementation of drivers is uh well yeah, but good for you man
thanks a lot man, I really appreciate your help!
Here are my specs:
GTAV looks like correct framerates
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
its all fixed up :)
Here are my specs:
