Why do you need risers in the first place? What are you trying to do?
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676400
1 minute ago, Bajantechnician said:
Hi guys. I have a x99 Asus formula 10, with 3 390xs. I have a power supply high enough so supply the power, but I'm not sure if I need powered risers, or normal riders. I'll be putting the cards in the suggested slots.
thanks
It's more important to get shielded risers more than anything else to ensure data integrity between the card and PCI-E slot.
http://ttpremium.com/product/pci-e-x16-riser-cable/
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676401
So I have 3 390xs, and the way the board is built, the cards physically won't fit due to slot positioning with 2.5 slot cards.
I agree. However, would i need powered shielded risers, or are normal shielded ones ok?
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676573
Usually it will be good with just shielded risers, some of the best ones would be the professional ones from 3M but do cost a pretty penny.
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676582
Then you just need regular shielded risers. No power.
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676656
Because I have seen hundreds of PCs using PCIe risers and they are all unpowered and less than 15cm.
If you need a really long one, then you might need it to be powered. Or if you need to deliver over 75W per slot. Not too sure tbh.
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676818
One 390x draws approximately 350 W I believe. However, they won't be longer than 15 cm :)
https://linustechtips.com/topic/673537-do-i-need-powered-risers/#findComment-8676902
