When Turning On TV My Triple Monitor Setup Flashes
Waffles!
Hello, I have a s Sony Bravia 4k tv and when I turn on it causes my triple monitor setup to flash for a few seconds then it goes back to normal. All the monitors are plugged in an EVGA GTX 1080 using dvi, 2x dp, and 1 dp to dvi. I also have a vive but it still does it with it plugged in. Anyone know how to fix this as every time I turn my monitors on it crashes my file backup program (EaseUS Todo) Thanks!
Can you describe the flashing? Is it like a repeated and or timed flash or just rapid fire? Could you record it?
Yeah, when I turn on the 3 1080p monitors dont flash but when I turn on the 4k tv it causes the monitors to turn black for about 1s then flash to my desktop wallpaper, go black for another second and this happens about 3 more times then everything goes back to normal
I believe it's a power issue, have you tried connecting your monitors in a different place in the house.
I'll try before I got to bed but it doesn't happen all the time, only when the monitors have been turned off for a few hours then it flashes when I turn them on. Also the monitors are connected to a UPS.
How is your TV connected? Do you use Displayfusion? It could be that the TV is changing the display config so that everything matches correctly.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
What is displayfusion, I would guess i'm not using it if its an application? And idk, the triple monitors are 1080p while the tv is 4k soo?
Can you try Displayfusion and see if the same occurs?
Yep, still does it sadly :(
How is the TV connected to the GPU?
Via HDMI
Is the TV itself being recognized? As in the model shows up and the driver is installed? Are the 3 1080's being used in surround mode?
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
I assume they flash when the TV turns on or are you plugging in a monitor/tv while the system is on and running?
Yes, its recognized in Geforce as Sony and the 3 1080s arnt in surround mode
Yep, when I turn them on, everything is already plugged in
Welp, I guess nobody knows how to fix this ;-;
According to your first post, how your monitors are connected correct. Is the tv connected via hdmi or no?
Yes, the tv is connected via HDMI
So when you turn the tv on is it already on hdmi input or does it have to be cycled?
on HDMI input all ready to go
